Maya2011 is installed and running on Fedore 11, while using the python interpeter included with Maya and running to following commands Maya exits with a fatal error.
import pymel.core
quit()
Note that pymel.core seems to import just fine, and I can use Maya within python, but upon issuing the quit() command the following message
*** glibc detected *** /usr/autodesk/maya2011-x64/bin/python-bin: double free or corruption (!prev): 0x0000000003ede4a0 ***
======= Backtrace: =========
/lib/libc.so.6(+0x775b6)[0x7fc0de8f95b6]
/lib/libc.so.6(cfree+0x73)[0x7fc0de8ffe53]
/usr/autodesk/maya2011-x64/bin/../lib/libBase.so(_ZN8awString7IStringD1Ev+0x38)[0x7fc0d41d8b38]
/lib/libc.so.6(exit+0xe2)[0x7fc0de8bb262]
/usr/autodesk/maya2011-x64/bin/../lib/libpython2.6.so.1.0(+0x10235f)[0x7fc0df5ae35f]
/usr/autodesk/maya2011-x64/bin/../lib/libpython2.6.so.1.0(+0x10245e)[0x7fc0df5ae45e]
/usr/autodesk/maya2011-x64/bin/../lib/libpython2.6.so.1.0(PyErr_PrintEx+0x1c8)[0x7fc0df5ae698]
/usr/autodesk/maya2011-x64/bin/../lib/libpython2.6.so.1.0(PyRun_SimpleFileExFlags+0x11a)[0x7fc0df5afb9a]
/usr/autodesk/maya2011-x64/bin/../lib/libpython2.6.so.1.0(Py_Main+0xadc)[0x7fc0df5bb36c]
/lib/libc.so.6(__libc_start_main+0xfd)[0x7fc0de8a0c4d]
/usr/autodesk/maya2011-x64/bin/python-bin[0x400619]
======= Memory map: ========
00400000-00401000 r-xp 00000000 08:01 144585 /usr/autodesk/maya2011-x64/bin/python-bin
00600000-00601000 rw-p 00000000 08:01 144585 /usr/autodesk/maya2011-x64/bin/python-bin
02257000-0a57b000 rw-p 00000000 00:00 0 [heap]
7fc0b0000000-7fc0b0021000 rw-p 00000000 00:00 0
7fc0b0021000-7fc0b4000000 ---p 00000000 00:00 0
7fc0b4a1f000-7fc0b4ae7000 rw-p 00000000 00:05 793 /dev/zero
7fc0b4ae7000-7fc0b4baf000 rw-p 00000000 00:05 793 /dev/zero
7fc0b4baf000-7fc0b4c77000 rw-p 00000000 00:05 793 /dev/zero
7fc0b4c77000-7fc0b4e4c000 r-xp 00000000 08:01 144601 /usr/autodesk/maya2011-x64/bin/plug-ins/mayaHIK.so
7fc0b4e4c000-7fc0b504c000 ---p 001d5000 08:01 144601 /usr/autodesk/maya2011-x64/bin/plug-ins/mayaHIK.so
7fc0b504c000-7fc0b5054000 rw-p 001d5000 08:01 144601 /usr/autodesk/maya2011-x64/bin/plug-ins/mayaHIK.so
7fc0b5054000-7fc0b508a000 rw-p 00000000 00:00 0
7fc0b508a000-7fc0b5090000 r-xp 00000000 08:01 144655 /usr/autodesk/maya2011-x64/bin/plug-ins/decomposeMatrix.so
7fc0b5090000-7fc0b528f000 ---p 00006000 08:01 144655 /usr/autodesk/maya2011-x64/bin/plug-ins/decomposeMatrix.so
7fc0b528f000-7fc0b5290000 rw-p 00005000 08:01 144655 /usr/autodesk/maya2011-x64/bin/plug-ins/decomposeMatrix.so
7fc0b5290000-7fc0b5358000 rw-p 00000000 00:05 793 /dev/zero
7fc0b5358000-7fc0b5420000 rw-p 00000000 00:05 793 /dev/zero
7fc0b5420000-7fc0b54e8000 rw-p 00000000 00:05 793 /dev/zero
7fc0b54e8000-7fc0b55b0000 rw-p 00000000 00:05 793 /dev/zero
7fc0b55b0000-7fc0b5678000 rw-p 00000000 00:05 793 /dev/zero
7fc0b5678000-7fc0b5740000 rw-p 00000000 00:05 793 /dev/zero
7fc0b5740000-7fc0b5808000 rw-p 00000000 00:05 793 /dev/zero
7fc0b5808000-7fc0b58d0000 rw-p 00000000 00:05 793 /dev/zero
7fc0b58d0000-7fc0b5998000 rw-p 00000000 00:05 793 /dev/zero
7fc0b5998000-7fc0b5b25000 r-xp 00000000 08:01 144602 /usr/autodesk/maya2011-x64/bin/plug-ins/MayaMuscle.so
7fc0b5b25000-7fc0b5d24000 ---p 0018d000 08:01 144602 /usr/autodesk/maya2011-x64/bin/plug-ins/MayaMuscle.so
7fc0b5d24000-7fc0b5d2b000 rw-p 0018c000 08:01 144602 /usr/autodesk/maya2011-x64/bin/plug-ins/MayaMuscle.so
7fc0b5d2b000-7fc0b5d35000 rw-p 00000000 00:00 0
7fc0b5d35000-7fc0b5d4e000 r-xp 00000000 08:01 144600 /usr/autodesk/maya2011-x64/bin/plug-ins/ikSpringSolver.so
7fc0b5d4e000-7fc0b5f4e000 ---p 00019000 08:01 144600 /usr/autodesk/maya2011-x64/bin/plug-ins/ikSpringSolver.so
7fc0b5f4e000-7fc0b5f4f000 rw-p 00019000 08:01 144600 /usr/autodesk/maya2011-x64/bin/plug-ins/ikSpringSolver.so
7fc0b5f4f000-7fc0b69df000 r-xp 00000000 08:01 144661 /usr/autodesk/maya2011-x64/bin/plug-ins/fbxmaya.so
7fc0b69df000-7fc0b6adf000 ---p 00a90000 08:01 144661 /usr/autodesk/maya2011-x64/bin/plug-ins/fbxmaya.so
7fc0b6adf000-7fc0b6b20000 rw-p 00a90000 08:01 144661 /usr/autodesk/maya2011-x64/bin/plug-ins/fbxmaya.so
7fc0b6b20000-7fc0b6b28000 rw-p 00000000 00:00 0
7fc0b6b28000-7fc0b6b2a000 r-xp 00000000 08:01 16460 /usr/autodesk/maya2011-x64/mentalray/lib/surfaceSampler.so
7fc0b6b2a000-7fc0b6d2a000 ---p 00002000 08:01 16460 /usr/autodesk/maya2011-x64/mentalray/lib/surfaceSampler.so
7fc0b6d2a000-7fc0b6d2b000 rw-p 00002000 08:01 16460 /usr/autodesk/maya2011-x64/mentalray/lib/surfaceSampler.so
7fc0b6d2b000-7fc0b6d47000 r-xp 00000000 08:01 16456 /usr/autodesk/maya2011-x64/mentalray/lib/subsurface.so
7fc0b6d47000-7fc0b6f46000 ---p 0001c000 08:01 16456 /usr/autodesk/maya2011-x64/mentalray/lib/subsurface.so
7fc0b6f46000-7fc0b6f47000 rw-p 0001b000 08:01 16456 /usr/autodesk/maya2011-x64/mentalray/lib/subsurface.so
7fc0b6f47000-7fc0b6f57000 r-xp 00000000 08:01 16453 /usr/autodesk/maya2011-x64/mentalray/lib/production.so
7fc0b6f57000-7fc0b7157000 ---p 00010000 08:01 16453 /usr/autodesk/maya2011-x64/mentalray/lib/production.so
7fc0b7157000-7fc0b7158000 rw-p 00010000 08:01 16453 /usr/autodesk/maya2011-x64/mentalray/lib/production.so
7fc0b7158000-7fc0b7165000 r-xp 00000000 08:01 16452 /usr/autodesk/maya2011-x64/mentalray/lib/physics.so
7fc0b7165000-7fc0b7364000 ---p 0000d000 08:01 16452 /usr/autodesk/maya2011-x64/mentalray/lib/physics.so
7fc0b7364000-7fc0b7365000 rw-p 0000c000 08:01 16452 /usr/autodesk/maya2011-x64/mentalray/lib/physics.so
7fc0b7365000-7fc0b736a000 r-xp 00000000 08:01 16462 /usr/autodesk/maya2011-x64/mentalray/lib/paint.so
7fc0b736a000-7fc0b7569000 ---p 00005000 08:01 16462 /usr/autodesk/maya2011-x64/mentalray/lib/paint.so
7fc0b7569000-7fc0b756a000 rw-p 00004000 08:01 16462 /usr/autodesk/maya2011-x64/mentalray/lib/paint.so
maya encountered a fatal error
Signal: 6 (Unknown Signal)
Segmentation fault
This does not seem good. I am running:
Maya 2011 Hotfix 3 x64, Cut Number 201007130209
I have tried this with several different flavors of linux (Fedora 11, Ubuntu Lucid Lynx) and the results, excluding memory address locations, look the same. Any assistance in this matter would be greatly appreciated.
