Hi all,
I have gotten the Renderman to load in Maya but now I can't see any render icons under the RENDERING tab nor can I select Renderman as the renderer.
It loads but Maya doesn't see it....any ideas?
Thank you!
Brian
@Anonymous wrote:
Hi all,
Thank you!
Brian
was it working before you loaded renderman?
if it was it sounds like Renderman is to blame
who makes this Add in? and have you tried contacting them for help?
DarrenP
Not sure I'm understanding what you're asking.
I can tell you that I was able to get Renderman loaded and operational within Maya months ago. I now had to come back to a projects and make it work again. Renderman will load (I always have to load it manually though the Plugins window in Maya though) but it will not show up as an option anywhere to render with.
The plugin was purchased from Pixar, installed into Maya 2013.5 originally. Nothing has changed to date.
Does that help?
Thank you for the repsonse,
Brian
try contacting pixar for help
don't know how much help your going to get here since this isn't an autodesk product
DarrenP
OK, thanks - will do. I wasn't sure if this was a common issue but judging by my searches online, no one else seems to be experiencing it.
