Installation & Licensing
Maya hangs upon launching with error in Command Window
6 REPLIES 6
3290 Views, 6 Replies
So I just installed Maya 2013 successfully the other night and used it.  Yay!  But tonight, it fails to fully open and has hung  up on me several times.  I had to reboot my Mac many times and every time I attempt to lauch Maya I get the dreaded Command Window error:
// Error: file: /Applications/Autodesk/maya2013/Maya.app/Contents/scripts/startup/layerEditor.mel line 4392: Could not find attribute named "defaultRenderLayer.precompTemplate" //
// AbcImport v1.0 using Alembic 1.0.4 (built Jan 16 2012 13:46:55)
// AbcExport v1.0 using Alembic 1.0.4 (built Jan 16 2012 13:46:55)
updateRendererUI;
I've tried deleting all my Maya stuff from my computer and re-installing the whole shebang but still no cigar.
I just doesn't work.  Boo!
Should I re-register and get a new code/download then?
6 REPLIES 6
david.lau
Delete your preferences and restart Maya. The folder is in:
WINDOWS
C:\Users\YOURUSERNAME\Documents\maya\2013-x64
MAC
Users > YOURUSERNAME > Library > Preferences > Autodesk > Maya > Maya  > 2013-x64
If that doesn't do it, uninstall (Delete) Maya and re-install it.  The 2012 instructions shoud be the same at the 2013 instructions.
http://upandready.typepad.com/up_and_ready/2012/04/maya-2012-on-mac-how-to-delete-maya-from-your-com...
David Lau
Okay, so I deleted what needed to be deleted, however, this did not solve my problem.
When I now attempt to install MAYA 2012 or 2013, Although I have 'Select your Os...' as a selection under the 'Operating Systems'  menu, the download page does not recognize that I have this selected and gives me this error:
http://students.autodesk.com
Please pick an operating system
I own a MacBook running the latest Os software...Installing Maya 2013 the first time, worked fine.  Why this error now??
david.lau
Please download the full updated version and use your EDU serial number here:
http://usa.autodesk.com/getdoc/id=DL19834912
Please note that Matchmover will not work so do not install that component for now.  You must use the original Maya 2013 release.
http://upandready.typepad.com/up_and_ready/2012/08/matchmover-2013-sp1-on-mac-error-tried-maya-2013-...
David Lau
in reply to: david.lau
I am having the same problem but with Maya 2015. I deleted Maya re installed and tried again. Then I deleted Maya and downloaded service pack 2, still nothing. I cannot seem to find the preferences file you referred to. I am using an iMac and I am running a student version of Maya. Please could you help me im not sure what else to do?
Tags (1)
This is what comes up in the command bar:
// Error: file: /Applications/Autodesk/maya2015/Maya.app/Contents/scripts/startup/layerEditor.mel line 4318: Could not find attribute named "defaultRenderLayer.precompTemplate" //
// mental ray for Maya 2015
// Mental ray for Maya: using startup file /Applications/Autodesk/mentalrayForMaya2015//maya.rayrc.
// mental ray for Maya: setup
// mental ray for Maya: initialize
// mental ray for Maya: register extensions
// mental ray Node Factory: loaded
// Error: file: /Applications/Autodesk/mentalrayForMaya2015/scripts/mentalrayUI.mel line 632: Cannot find procedure "loadPreferredPreset". //
// Error: file: /Applications/Autodesk/mentalrayForMaya2015/scripts/mentalrayUI.mel line 957: Cannot find procedure "loadPreferredPreset". //
// mental ray for Maya: successfully registered
// mental ray for Maya: loading startup file: /Applications/Autodesk/mentalrayForMaya2015//maya.rayrc
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/abcimport.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/abcimport.dylib
// generating Maya nodes...
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/AdskShaderSDKWrappers.mi
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/architectural.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/architectural.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/base.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/base.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/basehair.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/basehair.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/bifrostMR.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/bifrostMR.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/bifrostphenMR.mi
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/builtin_bsdf.mi
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/builtin_object_light.mi
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/contour.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/contour.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/layering.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/layering.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/layering_phen.mi
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/mrptex.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/mrptex.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/paint.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/paint.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/physics.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/physics.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/production.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/production.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/subsurface.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/subsurface.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/surfaceSampler.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/surfaceSampler.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/userdata.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/userdata.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/useribl.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/useribl.dylib
// parsing /Applications/Autodesk/mentalrayForMaya2015/shaders/include/xgenMR.mi
// loading /Applications/Autodesk/mentalrayForMaya2015/shaders/xgenMR.dylib
// AbcExport v1.0 using Alembic 1.5.0 (built Jul 26 2013 11:01:23)
// AbcImport v1.0 using Alembic 1.5.0 (built Jul 26 2013 11:01:23)
// Error: file: /Applications/Autodesk/maya2015/Maya.app/Contents/scripts/others/addSelectTypeItem.mel line 115: Cannot find procedure "updateSelectTypeItemState". //
// Error: line 1: initializePlugin function failed (gpuCache) //
updateRendererUI;
// Error: file: /Applications/Autodesk/mentalrayForMaya2015/scripts/mentalrayUI.mel line 1327: menu: Object 'mainRenderMenu' not found. //
// Error: file: /Applications/Autodesk/maya2015/plug-ins/xgen/scripts/muAddShelfButton.mel line 114: Object '' not found. //
updateRendererUI;
// Error: line 1: Cannot find procedure "MTsetToggleMenuItem". //
// Error: line 1: The renderer mayaSoftware is not registered yet. //
// Error: toolButton -q -ann $gNonSacredToolWidget; //
// Error: Line 1.41: "$gNonSacredToolWidget" is an undeclared variable. //
I am using the lastes Mac OSX
Tags (1)
I have the same issue, how did you solve it?
Administrator Productivity
