Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Maya License not obtained 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is very frustrating guys:
I have had Maya 2012 for almost a year with the edcuational license and suddenly, when opening maya, I get this message:
License was not obtained Tried Maya 2012 (657D1 2012.0.0.F), error 20
License method: environment variable MAYA_LICENSE_METHOD='standalone'
Product choice: environment variable MAYA_LICENSE='unlimited'
License file override: environment variable MAYA_ALT_EN is not set
Mac OSX 10.6.8
I have searched the issue, and followed steps in this thread http://forums.autodesk.com/t5/Installation-Licensi
without success. Can anyone help? What is this issue? Does this have to do with the nature of my educational license? Please help. Do I need to do a full system clean?
jake
Re: Maya License not obtained 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Educational licenses do expire. Are you sure you haven't reached the end of your term?
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Maya License not obtained 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having this issue as well. I've just downloaded Maya 2012 for Mac OS last night, and I'm getting this error even while trying to run it with in 30-day trial mode.I wanted an Educational license, now that I'm a teacher, but I saw the alert that they are currently broken. Great...
I've been through all the forums (apparently it is a common problem), and here's what I've tried so far:
Did a complete "clean" uninstall, according to Autodesk's instructions, using the adlmreg commands, etc.
Logged in as root and removed these directories (BEING CAREFUL TO BACK THEM UP FIRST!):
/Library/Preferences/FLEXnet Publisher/
/Library/Application Support/FLEXnet Publisher/
/Library/Application Support/Autodesk/
Removed all trace of old Maya versions I had floating around.
Re-installed Maya with the Service pack 2.
Nothing has made any difference, and I'm starting to get extremely ticked off. Help would be much appreciated!
