So i thought i bought a professional tool, and nwo i cannot even start it!!!!
I am on a MAC with Maverick.
Install went fine. When i start i need to click on activate.
which gives me
A license error has occured. Contact your technical support representive for assistance
Error Code 110!
After that:
License was not obtained
Tried Maya LT 2014 (myproductKey 2014.0.0.F), error 20
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
environment variable MAYA_LICENSE='unlimited'
License file override:
environment variable MAYA_ALT_EN is not set
so what is the problem, i cannot believe this!
Solved by lucentdreams. Go to Solution.
This maybe the issue. Maya LT 2014 is at the VERY bottom of the update page.
Hi, after trying lots of stuff it somehow did work in the end,
but it was not easy, had to delete some files in library.
Can you be more specific with what the fix was, I am currently having the same problem and it's driving me crazy.
thanx in advance for any help.
