Installation & Licensing
Maya Installer won't work on Mac
6 REPLIES 6
anne.moody
1663 Views, 6 Replies
Hello!
I am a uni student in desperate need of Maya, so I downloaded the student version. Unfortunately, when I tried to install, the launcher froze. Thinking it could be a problem of the file, I downloaded versions 2011 and 2010, but the same problem happened.
I searched a bit and it seems that this same error has happened on version 10.7 Lion of the Mac OSX, but I am running a
Mac OS X 10.6.8 Snow Leopard, and the machine is quite new. Any idea why this may be?
Thank you!
6 REPLIES 6
david.lau
in reply to: anne.moody
MarvinReyes
in reply to: david.lau
Hi, just recently bought Entertainment Creation Suite 2013. Having a problem installing to Mac OS X Leopard. Its says that 'it's not recognized and not mounting".
philip.s
in reply to: MarvinReyes
Hi MarvinReyes,
Have you checked out the component system requirements? From what I've seen so far, the Mac compatible products require OS X 10.7 or higher.
MarvinReyes
in reply to: philip.s
HI Philip,
Is there other way so i can install it? or i really need to upgrade my OS to Lion?
MarvinReyes
My OS is just 10.5.x.
Thanks!
Marvin
david.lau
Confirm that the OS is 1 out from this list.  i.e. Maya 2009 is tested for 10.4.  It will probably work with 10.5.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=14959955&linkID=9242259
If it doesn't install, then try "Pacifist'.  You can search for "Pacifist" in the Up and Ready blog (3rd column).
David Lau
Administrator Productivity
