• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    anne.moody
    Maya Installer won't work on Mac
    586 Views, 6 Replies
    10-25-2011 02:02 AM
    Hello!
    I am a uni student in desperate need of Maya, so I downloaded the student version. Unfortunately, when I tried to install, the launcher froze. Thinking it could be a problem of the file, I downloaded versions 2011 and 2010, but the same problem happened.
    I searched a bit and it seems that this same error has happened on version 10.7 Lion of the Mac OSX, but I am running a
    Mac OS X 10.6.8 Snow Leopard, and the machine is quite new. Any idea why this may be?
    Thank you!
    Please use plain text.
    Product Support
    Re: Maya Installer won't work on Mac
    10-26-2011 02:43 PM in reply to: anne.moody
    Member
    06-26-2012 01:55 AM in reply to: david.lau
    Hi, just recently bought Entertainment Creation Suite 2013. Having a problem installing to Mac OS X Leopard. Its says that 'it's not recognized and not mounting".
    philip.s
    06-26-2012 01:04 PM in reply to: MarvinReyes
    Hi MarvinReyes,
    Have you checked out the component system requirements? From what I've seen so far, the Mac compatible products require OS X 10.7 or higher.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Member
    06-26-2012 06:07 PM in reply to: philip.s
    HI Philip,
    Is there other way so i can install it? or i really need to upgrade my OS to Lion?
    Member
    06-26-2012 06:24 PM in reply to: philip.s
    My OS is just 10.5.x.
    Thanks!
    Marvin
    Product Support
    06-27-2012 06:08 AM in reply to: anne.moody
    Confirm that the OS is 1 out from this list.  i.e. Maya 2009 is tested for 10.4.  It will probably work with 10.5.
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=14959955&linkID=9242259
    If it doesn't install, then try "Pacifist'.  You can search for "Pacifist" in the Up and Ready blog (3rd column).
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
