Hi there!
I've read through a bunch of the articles here on this issue (though I didn't see any for 2015, though I imagine the issue is similar). I just downloaded the .exe file from Autodesk for the student version and I need it for a class in 3 days, I was hoping to install now so I can learn some basic features. I uninstalled all my Microsoft Visual C++ (x86) Redistributable files multiple times, rebootedmultiple times, re-downloaded the exe file and tried to install multiple times, all with the same error. I tried to find the setup.ini file, but since all I have right now is the downloaded .exe file I can't seem to find any way to actually locate the setup.ini file so I can follow Travis N.'s instructions for removing the prerequisite requirements. I checked that my .NET 3.5 is enabled in my Windows 8.1, at a total loss, been working on this for hours... below is my log files -
2014/7/11:07:23:54 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:23:54 Jeremy82many JEREMY Path_Length: 143
2014/7/11:07:23:54 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:07:23:54 Jeremy82many JEREMY Launch
2014/7/11:07:23:54 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:07:23:54 Jeremy82many JEREMY Setup Windows update reboot is pending
2014/7/11:07:27:49 Jeremy82many JEREMY Setup Autodesk Maya 2015 Will restart automatically.
2014/7/11:07:27:49 Jeremy82many JEREMY === Setup ended ===
2014/7/11:07:32:54 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:32:54 Jeremy82many JEREMY Path_Length: 143
2014/7/11:07:32:54 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:07:32:54 Jeremy82many JEREMY Launch
2014/7/11:07:32:54 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:07:32:54 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI37CA.tmp
2014/7/11:07:34:36 Jeremy82many JEREMY === Setup ended ===
2014/7/11:07:33:16 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:33:16 Jeremy82many JEREMY Path_Length: 143
2014/7/11:07:33:16 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI37CA.tmp
2014/7/11:07:33:16 Jeremy82many JEREMY Launch
2014/7/11:07:34:22 Jeremy82many JEREMY Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:07:34:35 Jeremy82many JEREMY Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:07:34:36 Jeremy82many JEREMY PageOpen LaunchDialog
2014/7/11:07:34:59 Jeremy82many JEREMY PageOpen LicenseDialog
2014/7/11:07:34:59 Jeremy82many JEREMY PageOpen ProductInfoDialog
2014/7/11:07:34:59 Jeremy82many JEREMY PageOpen ProductSelectionDialog2
2014/7/11:07:37:56 Jeremy82many JEREMY PageOpen FullProgressDialog
2014/7/11:07:37:58 Jeremy82many JEREMY Download Error Connection has expired. Please reconnect to site. VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:07:37:58 Jeremy82many JEREMY Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/7/11:07:37:58 Jeremy82many JEREMY PageOpen InstallCompleteDialog
2014/7/11:07:38:34 Jeremy82many JEREMY === Setup ended ===
2014/7/11:07:43:52 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:43:52 Jeremy82many JEREMY Path_Length: 143
2014/7/11:07:43:52 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:07:43:52 Jeremy82many JEREMY Launch
2014/7/11:07:43:52 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:07:43:52 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI4382.tmp
2014/7/11:07:44:01 Jeremy82many JEREMY === Setup ended ===
2014/7/11:07:43:54 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:43:54 Jeremy82many JEREMY Path_Length: 143
2014/7/11:07:43:54 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI4382.tmp
2014/7/11:07:43:54 Jeremy82many JEREMY Launch
2014/7/11:07:43:57 Jeremy82many JEREMY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:07:43:59 Jeremy82many JEREMY PageOpen LaunchDialog
2014/7/11:07:44:06 Jeremy82many JEREMY PageOpen LicenseDialog
2014/7/11:07:44:06 Jeremy82many JEREMY PageOpen ProductInfoDialog
2014/7/11:07:44:06 Jeremy82many JEREMY PageOpen ProductSelectionDialog2
2014/7/11:07:44:12 Jeremy82many JEREMY PageOpen FullProgressDialog
2014/7/11:07:44:13 Jeremy82many JEREMY Download Error Connection has expired. Please reconnect to site. VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:07:44:13 Jeremy82many JEREMY Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/7/11:07:44:14 Jeremy82many JEREMY PageOpen InstallCompleteDialog
2014/7/11:07:48:46 Jeremy82many JEREMY === Setup ended ===
2014/7/11:07:49:40 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:49:40 Jeremy82many JEREMY Path_Length: 143
2014/7/11:07:49:40 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:07:49:40 Jeremy82many JEREMY Launch
2014/7/11:07:49:40 Jeremy82many JEREMY CommandLine
2014/7/11:07:49:40 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI9236.tmp
2014/7/11:07:49:54 Jeremy82many JEREMY === Setup ended ===
2014/7/11:07:49:55 Jeremy82many JEREMY === Setup ended ===
2014/7/11:07:53:00 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:53:00 Jeremy82many JEREMY Path_Length: 143
2014/7/11:07:53:00 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:07:53:00 Jeremy82many JEREMY Launch
2014/7/11:07:53:00 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:07:53:00 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIA0ED.tmp
2014/7/11:07:53:47 Jeremy82many JEREMY === Setup ended ===
2014/7/11:07:53:01 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:07:53:01 Jeremy82many JEREMY Path_Length: 143
2014/7/11:07:53:01 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIA0ED.tmp
2014/7/11:07:53:01 Jeremy82many JEREMY Launch
2014/7/11:07:53:46 Jeremy82many JEREMY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:07:53:47 Jeremy82many JEREMY PageOpen LaunchDialog
2014/7/11:07:55:12 Jeremy82many JEREMY PageOpen LicenseDialog
2014/7/11:07:55:12 Jeremy82many JEREMY PageOpen ProductInfoDialog
2014/7/11:07:55:12 Jeremy82many JEREMY PageOpen ProductSelectionDialog2
2014/7/11:07:55:25 Jeremy82many JEREMY PageOpen FullProgressDialog
2014/7/11:07:55:28 Jeremy82many JEREMY Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/11:07:55:52 Jeremy82many JEREMY Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/11:07:55:52 Jeremy82many JEREMY Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/7/11:07:56:36 Jeremy82many JEREMY Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/7/11:07:56:37 Jeremy82many JEREMY Download Play VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/11:07:56:44 Jeremy82many JEREMY Download Complete VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/11:07:56:44 Jeremy82many JEREMY Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/7/11:07:57:42 Jeremy82many JEREMY Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/7/11:07:57:42 Jeremy82many JEREMY Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/7/11:07:57:47 Jeremy82many JEREMY Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...
2014/7/11:07:57:47 Jeremy82many JEREMY Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/7/11:07:57:57 Jeremy82many JEREMY Install DirectX® Runtime Succeeded
2014/7/11:07:57:57 Jeremy82many JEREMY Download Play ADAPPLICATIONMANAGER http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/ADAPPLICATI...
2014/7/11:07:58:20 Jeremy82many JEREMY Download Complete ADAPPLICATIONMANAGER http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/ADAPPLICATI...
2014/7/11:07:58:20 Jeremy82many JEREMY Installing Autodesk Application Manager: "C:\Autodesk\WI\Autodesk Maya 2015\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2014/7/11:07:59:29 Jeremy82many JEREMY Install Autodesk Application Manager Succeeded
2014/7/11:07:59:29 Jeremy82many JEREMY Download Play MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:00:01 Jeremy82many JEREMY Download User Pause MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:00:01 Jeremy82many JEREMY Download Paused MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:51:48 Jeremy82many JEREMY Download User Resume MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:51:51 Jeremy82many JEREMY Download Error MAYA <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:51:52 Jeremy82many JEREMY Download Aborted MAYA http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....
2014/7/11:08:51:52 Jeremy82many JEREMY Install Autodesk® Maya® 2015 Failed Download Failed, Installation aborted, Result=1603
2014/7/11:08:51:53 Jeremy82many JEREMY Rollback Autodesk Application Manager Failed Failure is ignored, Result=1619
2014/7/11:08:51:53 Jeremy82many JEREMY Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/7/11:08:51:53 Jeremy82many JEREMY Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/7/11:08:51:53 Jeremy82many JEREMY Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/7/11:08:51:53 Jeremy82many JEREMY PageOpen InstallCompleteDialog
2014/7/11:09:01:55 Jeremy82many JEREMY === Setup ended ===
2014/7/11:09:04:23 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:04:23 Jeremy82many JEREMY Path_Length: 143
2014/7/11:09:04:23 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:09:04:23 Jeremy82many JEREMY Launch
2014/7/11:09:04:23 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:09:04:24 Jeremy82many JEREMY Path_Length: 143
2014/7/11:09:04:24 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIFBE2.tmp
2014/7/11:09:04:31 Jeremy82many JEREMY === Setup ended ===
2014/7/11:09:04:25 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:04:25 Jeremy82many JEREMY Path_Length: 143
2014/7/11:09:04:25 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIFBE2.tmp
2014/7/11:09:04:25 Jeremy82many JEREMY Launch
2014/7/11:09:04:28 Jeremy82many JEREMY Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:09:04:28 Jeremy82many JEREMY Connection has expired. Please reconnect to site.2014/7/11:09:04:32 Jeremy82many JEREMY === Setup ended ===
2014/7/11:09:07:50 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:07:50 Jeremy82many JEREMY Path_Length: 143
2014/7/11:09:07:50 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:09:07:50 Jeremy82many JEREMY Launch
2014/7/11:09:07:50 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:09:07:50 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI20EF.tmp
2014/7/11:09:08:37 Jeremy82many JEREMY === Setup ended ===
2014/7/11:09:07:51 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:07:51 Jeremy82many JEREMY Path_Length: 143
2014/7/11:09:07:51 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI20EF.tmp
2014/7/11:09:07:51 Jeremy82many JEREMY Launch
2014/7/11:09:07:54 Jeremy82many JEREMY Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:09:07:54 Jeremy82many JEREMY Connection has expired. Please reconnect to site.2014/7/11:09:08:37 Jeremy82many JEREMY === Setup ended ===
2014/7/11:09:22:53 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:22:53 Jeremy82many JEREMY Path_Length: 143
2014/7/11:09:22:53 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:09:22:53 Jeremy82many JEREMY Launch
2014/7/11:09:22:53 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:09:22:53 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIBE7B.tmp
2014/7/11:09:23:33 Jeremy82many JEREMY === Setup ended ===
2014/7/11:09:22:56 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:22:56 Jeremy82many JEREMY Path_Length: 143
2014/7/11:09:22:56 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIBE7B.tmp
2014/7/11:09:22:56 Jeremy82many JEREMY Launch
2014/7/11:09:23:33 Jeremy82many JEREMY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:09:23:33 Jeremy82many JEREMY PageOpen LaunchDialog
2014/7/11:09:23:51 Jeremy82many JEREMY PageOpen LicenseDialog
2014/7/11:09:23:51 Jeremy82many JEREMY PageOpen ProductInfoDialog
2014/7/11:09:23:51 Jeremy82many JEREMY PageOpen ProductSelectionDialog2
2014/7/11:09:25:08 Jeremy82many JEREMY PageOpen FullProgressDialog
2014/7/11:09:25:10 Jeremy82many JEREMY Download Error Connection has expired. Please reconnect to site. VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:09:25:10 Jeremy82many JEREMY Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/7/11:09:25:10 Jeremy82many JEREMY PageOpen InstallCompleteDialog
2014/7/11:09:46:47 Jeremy82many JEREMY === Setup ended ===
2014/7/11:09:53:47 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:53:47 Jeremy82many JEREMY Path_Length: 143
2014/7/11:09:53:47 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:09:53:47 Jeremy82many JEREMY Launch
2014/7/11:09:53:47 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:09:53:47 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIB74B.tmp
2014/7/11:09:55:17 Jeremy82many JEREMY === Setup ended ===
2014/7/11:09:53:48 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:09:53:48 Jeremy82many JEREMY Path_Length: 143
2014/7/11:09:53:48 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIB74B.tmp
2014/7/11:09:53:48 Jeremy82many JEREMY Launch
2014/7/11:09:54:33 Jeremy82many JEREMY Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:09:54:33 Jeremy82many JEREMY Connection has expired. Please reconnect to site.2014/7/11:09:55:18 Jeremy82many JEREMY === Setup ended ===
2014/7/11:10:00:28 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:00:28 Jeremy82many JEREMY Path_Length: 143
2014/7/11:10:00:28 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:10:00:28 Jeremy82many JEREMY Launch
2014/7/11:10:00:28 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:10:00:28 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AID545.tmp
2014/7/11:10:00:34 Jeremy82many JEREMY === Setup ended ===
2014/7/11:10:00:29 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:00:29 Jeremy82many JEREMY Path_Length: 143
2014/7/11:10:00:29 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AID545.tmp
2014/7/11:10:00:29 Jeremy82many JEREMY Launch
2014/7/11:10:00:30 Jeremy82many JEREMY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:10:00:34 Jeremy82many JEREMY PageOpen LaunchDialog
2014/7/11:10:02:18 Jeremy82many JEREMY PageOpen LicenseDialog
2014/7/11:10:02:18 Jeremy82many JEREMY PageOpen ProductInfoDialog
2014/7/11:10:02:18 Jeremy82many JEREMY PageOpen ProductSelectionDialog2
2014/7/11:10:02:23 Jeremy82many JEREMY PageOpen FullProgressDialog
2014/7/11:10:02:24 Jeremy82many JEREMY Download Error Connection has expired. Please reconnect to site. VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:10:02:24 Jeremy82many JEREMY Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/7/11:10:02:24 Jeremy82many JEREMY PageOpen InstallCompleteDialog
2014/7/11:10:22:38 Jeremy82many JEREMY === Setup ended ===
2014/7/11:10:27:22 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:27:22 Jeremy82many JEREMY Path_Length: 143
2014/7/11:10:27:22 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:10:27:22 Jeremy82many JEREMY Launch
2014/7/11:10:27:22 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:10:27:22 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AID2D2.tmp
2014/7/11:10:27:27 Jeremy82many JEREMY === Setup ended ===
2014/7/11:10:27:23 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:27:23 Jeremy82many JEREMY Path_Length: 143
2014/7/11:10:27:23 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AID2D2.tmp
2014/7/11:10:27:23 Jeremy82many JEREMY Launch
2014/7/11:10:27:24 Jeremy82many JEREMY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:10:27:27 Jeremy82many JEREMY PageOpen LaunchDialog
2014/7/11:10:27:41 Jeremy82many JEREMY === Setup ended ===
2014/7/11:10:28:07 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:28:07 Jeremy82many JEREMY Path_Length: 143
2014/7/11:10:28:07 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:10:28:07 Jeremy82many JEREMY Launch
2014/7/11:10:28:07 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:10:28:07 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI8113.tmp
2014/7/11:10:28:14 Jeremy82many JEREMY === Setup ended ===
2014/7/11:10:28:08 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:28:08 Jeremy82many JEREMY Path_Length: 143
2014/7/11:10:28:08 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI8113.tmp
2014/7/11:10:28:08 Jeremy82many JEREMY Launch
2014/7/11:10:28:11 Jeremy82many JEREMY Download Error Connection has expired. Please reconnect to site. SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:10:28:11 Jeremy82many JEREMY Connection has expired. Please reconnect to site.2014/7/11:10:28:15 Jeremy82many JEREMY === Setup ended ===
2014/7/11:10:29:27 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:29:27 Jeremy82many JEREMY Path_Length: 143
2014/7/11:10:29:27 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:10:29:27 Jeremy82many JEREMY Launch
2014/7/11:10:29:27 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:10:29:27 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIB9F1.tmp
2014/7/11:10:29:31 Jeremy82many JEREMY === Setup ended ===
2014/7/11:10:29:28 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:29:28 Jeremy82many JEREMY Path_Length: 143
2014/7/11:10:29:28 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AIB9F1.tmp
2014/7/11:10:29:28 Jeremy82many JEREMY Launch
2014/7/11:10:29:28 Jeremy82many JEREMY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:10:29:29 Jeremy82many JEREMY PageOpen LaunchDialog
2014/7/11:10:29:37 Jeremy82many JEREMY PageOpen LicenseDialog
2014/7/11:10:29:37 Jeremy82many JEREMY PageOpen ProductInfoDialog
2014/7/11:10:29:37 Jeremy82many JEREMY PageOpen ProductSelectionDialog2
2014/7/11:10:29:41 Jeremy82many JEREMY PageOpen FullProgressDialog
2014/7/11:10:29:43 Jeremy82many JEREMY Download Error Connection has expired. Please reconnect to site. VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:10:29:43 Jeremy82many JEREMY Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
2014/7/11:10:29:43 Jeremy82many JEREMY PageOpen InstallCompleteDialog
2014/7/11:10:36:24 Jeremy82many JEREMY === Setup ended ===
2014/7/11:10:37:29 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:37:29 Jeremy82many JEREMY Path_Length: 143
2014/7/11:10:37:29 Jeremy82many JEREMY Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/11:10:37:29 Jeremy82many JEREMY Launch
2014/7/11:10:37:29 Jeremy82many JEREMY CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-43815107 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/11:10:37:29 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI1638.tmp
2014/7/11:10:37:35 Jeremy82many JEREMY === Setup ended ===
2014/7/11:10:37:30 Jeremy82many JEREMY === Setup started on JEREMY by Jeremy82many ===
2014/7/11:10:37:30 Jeremy82many JEREMY Path_Length: 143
2014/7/11:10:37:30 Jeremy82many JEREMY Current Directory C:\Users\JEREMY~1\AppData\Local\Temp\_AI1638.tmp
2014/7/11:10:37:30 Jeremy82many JEREMY Launch
2014/7/11:10:37:31 Jeremy82many JEREMY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/11:10:37:33 Jeremy82many JEREMY PageOpen LaunchDialog
2014/7/11:10:37:38 Jeremy82many JEREMY PageOpen LicenseDialog
2014/7/11:10:37:38 Jeremy82many JEREMY PageOpen ProductInfoDialog
2014/7/11:10:37:38 Jeremy82many JEREMY PageOpen ProductSelectionDialog2
2014/7/11:10:37:43 Jeremy82many JEREMY PageOpen FullProgressDialog
2014/7/11:10:37:45 Jeremy82many JEREMY Download Error Connection has expired. Please reconnect to site. VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/11:10:37:45 Jeremy82many JEREMY Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Download Failed, Installation aborted, Result=1603
Solved by ShamanicHarmonics. Go to Solution.
I do see that I forgot to mention I also disabled my antivirus, firewall, and UAC.
After somemore searching I found that the answer to this thread, with the installer downloads solved my problems 🙂
