Installation & Licensing
Member
hammerowns
Message 1 of 8 (1,168 Views)
Maya 2015 Installation Error
1168 Views, 7 Replies
04-17-2014 08:29 PM
Hey everybody,
Recently I have been trying to install Maya 2015 but keep stumbling upon the same error message part-way through installation.
I have tried downloading and installing via multiple methods aswell as deleting all files I could find from previous installations and trying again but consistantly get the same error.
My PC is currently running Windows 7 64bit, additional details can be provided if it would help.
Any help would be much appreciated, thanks, Thor
New Member
c.coward
Message 2 of 8 (1,126 Views)
Re: Maya 2015 Installation Error
04-18-2014 12:13 AM in reply to: hammerowns
The same thing happened to me at first.. The issue may be your virus protection software. It will read the bifrost as a false positive during dowload and delete it before you even get to install.. Try disabling your virus protection until it's installed.
Member
hammerowns
Message 3 of 8 (1,102 Views)
04-18-2014 09:15 AM in reply to: c.coward
This worked after re-downloading and re-installing Maya, I can't thank you enough!
For anybody curious it was Avast causing the false positive.
Thanks again!
Member
alan
Message 4 of 8 (1,094 Views)
04-18-2014 10:48 AM in reply to: hammerowns
I uninstalled and reinstalled without Avast running and got the same error. I had to delete the files out of C:\Autodesk\WI\Autodesk Maya 2015 before it will install properly.
Member
hammerowns
Message 5 of 8 (1,090 Views)
04-18-2014 10:54 AM in reply to: alan
Yeah, the files need to be entirely re-downloaded and so you must delete the others, what was happening with mine was the file in question was for some reason turned into a .bin file rather than a .dll.
Member
alan
Message 6 of 8 (1,084 Views)
04-18-2014 11:39 AM in reply to: hammerowns
Noting the same thing, I did try to rename it back from bin to dll and that let me complete the install just fine. However, when I went to try to use on of the sample scenes, the bifrost node did not work properly.
Member
hammerowns
Message 7 of 8 (1,080 Views)
04-18-2014 12:23 PM in reply to: alan
There is probably some issue with simply changing the file extension of a binary file to a .dll where the data becomes unusable. Glad that we have it fixed though :smileyhappy:.
New Member
crazy49
Message 8 of 8 (819 Views)
05-19-2014 12:42 AM in reply to: hammerowns
I had the same problem yesterday, and I found a way to fix this Error.
Befor you install Maya 2015, set the secure level from your Windowsprofil to the lowest level,
and deativate Avast. After the instalation of Maya 2015, you can change the scure level back.
Sorry for my bad english, but i hope this help you to fix this error.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
