Installation & Licensing
2483 Views, 4 Replies
Maya 2015 Errors
2014/4/16:19:20:52 Logan LOGAN-PC PageOpen LicenseDialog
2014/4/16:19:20:56 Logan LOGAN-PC PageOpen ProductSelectionDialog2
2014/4/16:19:20:59 Logan LOGAN-PC PageOpen LicenseDialog
2014/4/16:19:21:00 Logan LOGAN-PC PageOpen LaunchDialog
2014/4/16:19:21:04 Logan LOGAN-PC PageOpen LicenseDialog
2014/4/16:19:21:11 Logan LOGAN-PC PageOpen ProductInfoDialog
2014/4/16:19:21:16 Logan LOGAN-PC PageOpen ProductSelectionDialog2
2014/4/16:19:21:23 Logan LOGAN-PC PageOpen FullProgressDialog
2014/4/16:19:21:23 Logan LOGAN-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2015_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/16:19:21:52 Logan LOGAN-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/16:19:21:52 Logan LOGAN-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Maya_2015_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/16:19:22:53 Logan LOGAN-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/16:19:22:53 Logan LOGAN-PC Installing DirectX® Runtime: "C:\Autodesk\Autodesk_Maya_2015_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/16:19:23:50 Logan LOGAN-PC Install DirectX® Runtime Succeeded
2014/4/16:19:23:53 Logan LOGAN-PC Installing Autodesk® Maya® 2015: TRANSFORMS="C:\Users\Logan\AppData\Local\Temp\_AI4C55.tmp\x64\Maya\Maya-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Maya_2015_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Maya2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/16:19:43:54 Logan LOGAN-PC Install Autodesk® Maya® 2015 Failed Installation aborted, Result=1603
2014/4/16:19:43:55 Logan LOGAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/16:19:43:55 Logan LOGAN-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/16:19:43:55 Logan LOGAN-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
4 REPLIES 4
TravisNave
That's a pretty long and deep pathname.  You might consider moving the Autodesk_Maya_2015_... folder to the root and just rename it C:\Maya.  That will drastically shorten the length and depth.  Might work on the next try.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
c.coward
The same thing happened to me at first.. The issue may be your virus protection software. It will read the bifrost as a false positive during dowload and delete it before you even get to install.. Try disabling your virus protection until it's installed.
in reply to: c.coward
Thank you, I had the same problem as well. Disabling my virus protection software did the trick.
GibranJPawling
Go to that file and change the extension to .dll
That worked to me 😉
Administrator Productivity
