2014/4/16:19:20:52 Logan LOGAN-PC PageOpen LicenseDialog
2014/4/16:19:20:56 Logan LOGAN-PC PageOpen ProductSelectionDialog2
2014/4/16:19:20:59 Logan LOGAN-PC PageOpen LicenseDialog
2014/4/16:19:21:00 Logan LOGAN-PC PageOpen LaunchDialog
2014/4/16:19:21:04 Logan LOGAN-PC PageOpen LicenseDialog
2014/4/16:19:21:11 Logan LOGAN-PC PageOpen ProductInfoDialog
2014/4/16:19:21:16 Logan LOGAN-PC PageOpen ProductSelectionDialog2
2014/4/16:19:21:23 Logan LOGAN-PC PageOpen FullProgressDialog
2014/4/16:19:21:23 Logan LOGAN-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Maya_2015_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/16:19:21:52 Logan LOGAN-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/16:19:21:52 Logan LOGAN-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Maya_2015_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/16:19:22:53 Logan LOGAN-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/16:19:22:53 Logan LOGAN-PC Installing DirectX® Runtime: "C:\Autodesk\Autodesk_Maya_2015_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/16:19:23:50 Logan LOGAN-PC Install DirectX® Runtime Succeeded
2014/4/16:19:23:53 Logan LOGAN-PC Installing Autodesk® Maya® 2015: TRANSFORMS="C:\Users\Logan\AppData\Local\Temp\_AI4C55.tmp\x64\Maya\Maya-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Maya_2015_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Maya2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/16:19:43:54 Logan LOGAN-PC Install Autodesk® Maya® 2015 Failed Installation aborted, Result=1603
2014/4/16:19:43:55 Logan LOGAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/16:19:43:55 Logan LOGAN-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/16:19:43:55 Logan LOGAN-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
That's a pretty long and deep pathname. You might consider moving the Autodesk_Maya_2015_... folder to the root and just rename it C:\Maya. That will drastically shorten the length and depth. Might work on the next try.
The same thing happened to me at first.. The issue may be your virus protection software. It will read the bifrost as a false positive during dowload and delete it before you even get to install.. Try disabling your virus protection until it's installed.
