Installation & Licensing
Maya 2014 crashes on splash screen
3 REPLIES 3
531 Views, 3 Replies
Hi, I have been having a problem since Monday night 😞 I have been working with Maya 2014 with the student version (on Windows 😎 for a while and I haven't have any real proble until now. I was working on a model for a school project and had to go away for a while so I closed Maya and when I returned I couldn't open it again, it shows the output window and the splash screen but a few seconds after the splash shows, it immediatly closes without showing the error report window. I have already reinstalled it and still have the same problem.
Any ideas on how to repair this?
Thanks guys.
3 REPLIES 3
TravisNave
That behavior is almost certainly a license issue.  Sometimes licensing goes awol.  You'll likely have to blow away the adsk licensing files and reactivate.
They are located here:
%programdata%\flexnet\adsk*.data
The log file in that folder should confirm it.  I recommend backing up the files first.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
I come across with almost the same problem on my mac, and here is my post:
http://forums.autodesk.com/t5/Installation-Licensing/Crashed-opening-a-scene/m-p/5051538#M87497
Any idea? Same solution, or maybe it's differernt on mac and maya 2015? Plz help me
Hey!
After tryiung several things I figured out that at least in my case what happened is that some Python files had suddenly broke... I reinstalled Python and it worked again.
Hopefully this can help you.
Administrator Productivity
