Hi , whenever i open maya it gives me the attached error . i've uninstalled it and then re-installed it , but later when i shut my computer and then re-open it the error is back ,
i'm using Maya 2014 student licence, Core i7 processor, windows 7, Nvidea Greforce 520 M
i'd appreciate your help
thanks
Solved by david.lau. Go to Solution.
Do you have local admin rights? Might also set an exception in your anti-virus.
Delete your prefs and start again.
C:\Users\YOUR_USER_NAME\Documents\maya\2014-x64
Open Maya first before opening the file.
What video card are you running? If you are running a Geforce card, can you try to run it is a default graphics mode?
http://upandready.typepad.com/.a/6a0147e3c68bef970b019aff0e2c0e970c-pi
You could try installing an updated driver and see if it still crashes. Otherwise, new video cards are really affordable these days.
Once you run in Intel Mode, quit, and run in Geforce Mode. Does it still crash? I know that a M card is on a laptop so it will be hard to upgrade hardware.
