Installation & Licensing
Maya 2014 crash on startup
9 REPLIES 9
Message 1 of 10
3116 Views, 9 Replies
Hi , whenever i open maya it gives me the attached error . i've uninstalled it and then re-installed it , but later when i shut my computer and then re-open it the error is back ,
i'm using Maya 2014 student licence, Core i7 processor, windows 7, Nvidea Greforce 520 M
i'd appreciate your help
thanks
9 REPLIES 9
Message 2 of 10
TravisNave
Do you have local admin rights?  Might also set an exception in your anti-virus.
Autodesk Forums:
Message 3 of 10
david.lau
Delete your prefs and start again.
C:\Users\YOUR_USER_NAME\Documents\maya\2014-x64
Open Maya first before opening the file.
David Lau
Message 4 of 10
in reply to: TravisNave
thank you for your reply but yes i have
Message 5 of 10
in reply to: david.lau
i deleted the prefs but it didn't help 😞 and i'm just opening maya not a file i don't know what is it trying to save
Message 6 of 10
david.lau
What video card are you running?  If you are running a Geforce card, can you try to run it is a default graphics mode?
http://upandready.typepad.com/.a/6a0147e3c68bef970b019aff0e2c0e970c-pi
David Lau
Message 7 of 10
My Nvidia is the default but i tried running it with the intel card and it is now working :))) but my intel card is just 512 mb so i guess it won't handle large scenes :S but it solved the problem thank you so much 🙂 but what should i do with my Geforce card ?
Message 8 of 10
TravisNave
You could try installing an updated driver and see if it still crashes.  Otherwise, new video cards are really affordable these days.
Autodesk Forums:
Message 9 of 10
david.lau
Once you run in Intel Mode, quit, and run in Geforce Mode.  Does it still crash?  I know that a M card is on a laptop so it will be hard to upgrade hardware.
David Lau
Message 10 of 10
it didn't crash . thank you so much . i really appreciate your help
Administrator Productivity
