Hi, I have been trying to install maya for the last couple hours but everytime all the installs fail to download. Can someone help me out?
Here is the instalation log:
2014/4/12:11:34:47 Yasin YASIN === Setup started on YASIN by Yasin ===
2014/4/12:11:34:47 Yasin YASIN Path_Length: 151
2014/4/12:11:34:47 Yasin YASIN Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/4/12:11:34:47 Yasin YASIN Launch
2014/4/12:11:34:47 Yasin YASIN CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/12:11:34:47 Yasin YASIN Current Directory C:\Users\Yasin\AppData\Local\Temp\_AI519E.tmp
2014/4/12:11:34:49 Yasin YASIN === Setup ended ===
2014/4/12:11:34:48 Yasin YASIN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.t...
2014/4/12:11:34:49 Yasin YASIN PageOpen LaunchDialog
2014/4/12:11:34:51 Yasin YASIN PageOpen LicenseDialog
2014/4/12:11:34:51 Yasin YASIN PageOpen ProductInfoDialog
2014/4/12:11:35:16 Yasin YASIN PageOpen ProductSelectionDialog2
2014/4/12:11:35:17 Yasin YASIN PageOpen FullProgressDialog
2014/4/12:11:35:17 Yasin YASIN Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.tar...
2014/4/12:11:35:17 Yasin YASIN Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/12:11:35:43 Yasin YASIN Install DirectX® Runtime Succeeded
2014/4/12:11:35:43 Yasin YASIN Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US....
2014/4/12:11:45:40 Yasin YASIN Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US....
2014/4/12:11:45:40 Yasin YASIN Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/4/12:11:45:40 Yasin YASIN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
