• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Maya 2013 language
    637 Views, 4 Replies
    01-10-2013 06:42 AM
    I've downloaded english Maya 2013 but after I've installed it and ran it, it is in Chinese instead.
    I've tried re-installing several times and it iremained in Chinese language.
    May I know how to change the language of my Maya 2013 programme?
    Please use plain text.
    TravisNave
    Re: Maya 2013 language
    01-10-2013 08:28 AM in reply to: ice_dragoon93
    Did you download this legally from Autodesk?  And is your Windows a Chinese version?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    01-10-2013 11:34 AM in reply to: TravisNave
    Yes, I believe I did. I'm a student and registered under student/educator to download it for non-commercial use.
    My windows is in English as well.
    *Also, when downloading there was only 1 option for language: English. So it baffles me even further because, Chinese was not in the list in the first place and I've no idea how it got there.
    *Also, I tried using the "Install now" option but a "Communication Failure" message keep appearing. So, I used the "download" option to install instead and that led to the problem I'm facing right now (Language).
    philip.s
    01-10-2013 03:25 PM in reply to: ice_dragoon93
    Hi Calvin,
    The Maya 2013 download / installer contains the English, Japanese, and Chinese language options.
    Check out this Maya Online Help solution for a potential language switch, specifically by changing the MAYA_UI_LANGUAGE Environment Variable to en_US, in your system properties / advanced system settings.
    Please let us know if this works out / accept as a solution if this fully resolves the issue.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Member
    01-10-2013 08:32 PM in reply to: philip.s
    Hi Philip,
    It worked! Thanks a lot :smileyvery-happy:.
