Installation & Licensing
tsefreeflow
768 Views, 1 Reply
Maya 2013 install errors
So I am trying to install Maya 2013 32bit on my laptop so I can take it with me and work outside of my office. I purchased 2014 and earlier versions and have them all on my desktop in the office runing 64bit on a fast machine. This laptop is a workstation but older. It has 2010 installed now and works. It is 32bit XP professional on the laptop. I install with the serial number and it finishes successfully. When I run it, the scriot editor pops up with the following errors:
Can anyone assist? Appreciate it
// Warning: //
// Warning: //
// Warning: //
// Warning: //
// Warning: //
// Warning: //
// Warning: //
// Warning: //
// Warning: //
// Warning: //
// Warning: //
// Error: DSO <KinUISlice.dll > failed to load properly or perhaps commandList is incorrect. //
// Error: Error evaluating argument at position 1 in procedure "rememberCtxSettings". //
// Error: Unable to dynamically load : C:/Program Files/Autodesk/Maya2010/bin/plug-ins/rotateHelper.mll
The specified procedure could not be found.
// Error: The specified procedure could not be found.
(rotateHelper) //
// Error: Unable to dynamically load : C:/Program Files/Autodesk/Maya2010/bin/plug-ins/ik2Bsolver.mll
(ik2Bsolver) //
// Error: Unable to dynamically load : C:/Program Files/Autodesk/Maya2010/bin/plug-ins/Mayatomr.mll
(Mayatomr) //
// Error: Unable to dynamically load : C:/Program Files/Autodesk/Maya2010/bin/plug-ins/VectorRender.mll
(VectorRender) //
// Error: Unable to dynamically load : C:/Program Files/Autodesk/Maya2010/bin/plug-ins/DirectConnect.mll
(DirectConnect) //
// Error: Unable to dynamically load : C:/Program Files/Autodesk/Maya2010/bin/plug-ins/fbxmaya.mll
(fbxmaya) //
// Error: Unable to dynamically load : C:/Program Files/Autodesk/Maya2010/bin/plug-ins/ikSpringSolver.mll
(ikSpringSolver) //
// Error: Unable to dynamically load : C:/Program Files/Autodesk/Maya2010/bin/plug-ins/MayaMuscle.mll
(MayaMuscle) //
// Error: Unable to dynamically load : C:/Program Files/Autodesk/Maya2010/bin/plug-ins/compositingInterop.mll
(compositingInterop) //
1 REPLY 1
TravisNave
in reply to: tsefreeflow
Verify those file locations exist.  You might have to reinstall.  If you do, make sure you install with local admin rights and especially your anti-virus disabled.
Autodesk Forums:
Administrator Productivity
