Installation & Licensing
Member
Message 1 of 6 (4,216 Views)
[Maya 2013] All Products Failed to Install
4216 Views, 5 Replies
10-16-2012 11:59 AM
Hello
I have a problem since I want to install Maya 2013, but I can't. I've tried several times now and I have not been able to find a solution on the internet.
I tell the installer to install everything and then it begins installing. A few seconds after I see the Maya Logo, I get a weird box with information about console commands for Windows. I press OK and a few seconds after, the installer exits and tells me all 5 products failed to install.
I am running Windows 7 64 Bit Home Edition. I am installing the Educational Version of Autodesk Maya 2013.
The log:
2012/10/16:20:54:19 Vipar VIPAR-PC === Setup started on VIPAR-PC by Vipar ===
2012/10/16:20:54:19 Vipar VIPAR-PC Launch
2012/10/16:20:54:23 Vipar VIPAR-PC === Setup ended ===
2012/10/16:20:54:20 Vipar VIPAR-PC === Setup started on VIPAR-PC by Vipar ===
2012/10/16:20:54:20 Vipar VIPAR-PC Launch
2012/10/16:20:54:23 Vipar VIPAR-PC PageOpen LaunchDialog
2012/10/16:20:54:40 Vipar VIPAR-PC PageOpen LicenseDialog
2012/10/16:20:54:44 Vipar VIPAR-PC PageOpen ProductInfoDialog
2012/10/16:20:56:31 Vipar VIPAR-PC PageOpen ProductSelectionDialog2
2012/10/16:20:56:35 Vipar VIPAR-PC PageOpen FullProgressDialog
2012/10/16:20:56:35 Vipar VIPAR-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): C:\Autodesk\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Vipar\AppData\Local\Temp;C:\Program Files\Java\jre7\bin;C:\Program Files\Java\jre7\bin;\vcredist_x64_2005.log"" "
2012/10/16:20:56:52 Vipar VIPAR-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
Member
Message 2 of 6 (4,202 Views)
So I went into the Installation folders and manually inst...
10-16-2012 01:18 PM in reply to: xenon373
So I went into the Installation folders and manually installed the Redistributable that it kept stopping at, and the installer at least progress further now.
Member
Message 3 of 6 (4,194 Views)
Re: So I went into the Installation folders and manually inst...
10-16-2012 01:40 PM in reply to: xenon373
Yeah it works now.
New Member
Message 4 of 6 (4,140 Views)
Re: [Maya 2013] All Products Failed to Install
10-23-2012 02:44 PM in reply to: xenon373
Hey I am having the same issue! How did you manually install redistribute?
Member
Message 5 of 6 (4,138 Views)
10-23-2012 02:47 PM in reply to: u0700596
If you get all the installation files from either of the download options, some of the folders holds the redistributions of the programs. I simply went into those installation files and found the x64 and x86 folders. Then I just tried installing (some failed as they were already installed) and then I could install Maya 2013.
New Member
Message 6 of 6 (947 Views)
12-25-2013 05:11 AM in reply to: xenon373
Hey guys, i have the same problem and if i install these x64/x86 files there comes another problem o___O
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
