• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    [Maya 2013] All Products Failed to Install
    1631 Views, 4 Replies
    10-16-2012 11:59 AM
    Hello
    I have a problem since I want to install Maya 2013, but I can't. I've tried several times now and I have not been able to find a solution on the internet.
    I tell the installer to install everything and then it begins installing. A few seconds after I see the Maya Logo, I get a weird box with information about console commands for Windows. I press OK and a few seconds after, the installer exits and tells me all 5 products failed to install.
    I am running Windows 7 64 Bit Home Edition. I am installing the Educational Version of Autodesk Maya 2013.
    The log:
    2012/10/16:20:54:19 Vipar VIPAR-PC === Setup started on VIPAR-PC by Vipar ===
    2012/10/16:20:54:19 Vipar VIPAR-PC Launch
    2012/10/16:20:54:23 Vipar VIPAR-PC === Setup ended ===
    2012/10/16:20:54:20 Vipar VIPAR-PC === Setup started on VIPAR-PC by Vipar ===
    2012/10/16:20:54:20 Vipar VIPAR-PC Launch
    2012/10/16:20:54:23 Vipar VIPAR-PC PageOpen LaunchDialog
    2012/10/16:20:54:40 Vipar VIPAR-PC PageOpen LicenseDialog
    2012/10/16:20:54:44 Vipar VIPAR-PC PageOpen ProductInfoDialog
    2012/10/16:20:56:31 Vipar VIPAR-PC PageOpen ProductSelectionDialog2
    2012/10/16:20:56:35 Vipar VIPAR-PC PageOpen FullProgressDialog
    2012/10/16:20:56:35 Vipar VIPAR-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): C:\Autodesk\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Vipar\AppData\Local\Temp;C:\Program Files\Java\jre7\bin;C:\Program Files\Java\jre7\bin;\vcredist_x64_2005.log"" "
    2012/10/16:20:56:52 Vipar VIPAR-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
    Please use plain text.
    Member
    So I went into the Installation folders and manually inst...
    10-16-2012 01:18 PM in reply to: xenon373
    So I went into the Installation folders and manually installed the Redistributable that it kept stopping at, and the installer at least progress further now.
    Member
    Re: So I went into the Installation folders and manually inst...
    10-16-2012 01:40 PM in reply to: xenon373
    Yeah it works now.
    New Member
    Re: [Maya 2013] All Products Failed to Install
    10-23-2012 02:44 PM in reply to: xenon373
    Hey I am having the same issue! How did you manually install redistribute?
    Member
    10-23-2012 02:47 PM in reply to: u0700596
    If you get all the installation files from either of the download options, some of the folders holds the redistributions of the programs. I simply went into those installation files and found the x64 and x86 folders. Then I just tried installing (some failed as they were already installed) and then I could install Maya 2013.
