• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    tani
    Maya 2012 say its already installed
    114 Views, 2 Replies
    02-06-2012 02:34 PM
    Had maya 2012 and 2011 and 2009 installed  had one other unrelated SW product on my machine crash.  Research in getting that problem fixed, suggested I uniinstall alll microsoft visual c++ libs and the re-install.. which I did... It hasnt worked yet... worse it killed maya 2011 and maya 2012.   (however, maya 2009 still worked, go figure..)  In the process I know one of the maya installs got corrupted.  I have now fixed all the installs except maya 2012  (this is  after trying to kill all versions of maya and related apps as well as raping and pillaging my registry as well as deleting all program entries of autoDesk, and using the microsoft fixit program for installs uninstalls)
      I could flatten my whole system and start from scratch, but I have many other large programs I use on my system I'd rather not lose that time.    There has got to be a way to install maya 2012 or 2011 in a different directory for emergencie/ quick fix  isnt there ??
    Suggestions ?
    ***Guru
    TravisNave
    Re: Maya 2012 say its already installed
    02-07-2012 08:34 AM in reply to: tani
    To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
    http://support.microsoft.com/mats/Program_Install_and_Uninstall
    For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
    For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    tani
    02-07-2012 06:00 PM in reply to: tani
    Thanks I got it sorted shortly after my first post ....
    Tani
