• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Maya 2012 SAP Fails to install: Thinks Maya is installed already
    520 Views, 2 Replies
    12-02-2011 02:59 PM
       I tried to update my Maya 2012 to the SAP today.  This requires uninstalling Maya.
      However, my uninstall failed, and I was forced to delete the 2012 directory, and let windows 7 discover that the program was gone. It now does not show Maya 2012 as in installed program. It does show the other 3 version (2009, 2010, 2011) that I have installed.
      I now cannot install the SAP at all, as it believes Maya 2012 to still be installed on my computer. The only options when running the installer are to install the extra package (Backburner, Composite, etc) that come bundled. And for some reason, the DMM plugin. I cant force it to install into the former location, nor is there an option to repair. Until I can somehow convince the installer that I really dont have Maya installed, I am w/out a copy of 2012 and I need it for production on Monday.
      I have run a registry cleaner in the hopes that it would remove this, but to no avail. I cannot find anyone else with this problem. Please advise.
    -Nat
    Please use plain text.
    Product Support
    INACTIVE_Timmy.DeAustria
    Re: Maya 2012 SAP Fails to install: Thinks Maya is installed already
    12-02-2011 06:20 PM in reply to: RafAnzovin3937
    Try running the Fixit utility from Microsoft that can be found here:
    http://support.microsoft.com/mats/Program_Install_and_Uninstall
    Hope this helps. Good luck.
    Timmy De Austria
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    New Member
    12-07-2011 09:58 AM in reply to: INACTIVE_Timmy.DeAustria
    Thanks Timmy, this worked for me! Great to know about this Utility in general. Not sure why it doesnt come with windows by default...
    Out of curiosity, is there any particular reason the installer was changed so that you cant just install over an existing installation or try to repair in installation anymore?
    Anyhow, thanks for your help.
