Hello there at Autodesk!
I'm having a problem installing Autodesk Maya on my Macbook Pro.
It downloaded fine, but when I double click the dmg file, an error comes up in a separate window reading 'Image: Autodesk_Maya_2012 Reason: Not Recognized'. I've searched the site and google and still can not find a solution.
Any help is greatly appreciated.
Shay.
Solved by samrecycler. Go to Solution.
Hi. Did you end up getting your .dmg/s to work?
I'm having the same problem with AutoCAD for Mac (Student download). I'm using a 2012 MacBook Air 13". Size of *.dmg is 245MB and is also "not recognized". Found this thread from another forum which may have a solution...
http://www.telltalegames.com/forums/showthread.php?t=27359
Guess I'll try it out anyway and let you know if it works.
jh
