Installation & Licensing
Maya 2012 Mac OSX 'Failed to recognise' error
6 REPLIES 6
syd105539
977 Views, 6 Replies
Hello there at Autodesk!
I'm having a problem installing Autodesk Maya on my Macbook Pro.
It downloaded fine, but when I double click the dmg file, an error comes up in a separate window reading 'Image: Autodesk_Maya_2012 Reason: Not Recognized'. I've searched the site and google and still can not find a solution.
Any help is greatly appreciated.
Shay.
6 REPLIES 6
david.lau
in reply to: syd105539
Please try to download Maya 2012 again.
David Lau
samrecycler
I am having the same issue only on my Imac and ive downloaded it several times with the same results. "Tips, Tricks", or reccomendations?
david.lau
in reply to: david.lau
What is the size of the .dmg file?
David Lau
temeraire519
My dmg file is 205.2 mb and I am having the same issue.
jordan.holden
Hi. Did you end up getting your .dmg/s to work?
I'm having the same problem with AutoCAD for Mac (Student download). I'm using a 2012 MacBook Air 13". Size of *.dmg is 245MB and is also "not recognized". Found this thread from another forum which may have a solution...
http://www.telltalegames.com/forums/showthread.php?t=27359
Guess I'll try it out anyway and let you know if it works.
jh
Nup. Didn't work.
Administrator Productivity
