hey guys im new here on the autodesk forum and sorry for using bad grammer cuz my arms are sore >.< anyway!.
I had recently installed Maya 2011 trail ver. everythin went well in the installation steps as usual but then when i tryed 2 start it up i got this:
--------------------------- ---------------------------License was not obtained
License method:environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:environment variable MAYA_LICENSE='unlimited'
License file override:environment variable MAYA_ALT_EN is not set
---------------------------OK ---------------------------
so that box basicly pops up... im running windows 7 and i used to run 3DS max on here perfectly but i needed a change so i went to maya and got this PLEASE HELP ME! 😧
You will need to uninstall Maya, reboot your computer and re-install it. Try installing it in Trial mode so that you have the options to enter a serial number upon first launch.
ehh.. tryed it... and i got the blank screen glitch with only 2 buttons then i did the steps 2 fix it , it fixed it.
but then i got this same error again! 😧
