Installation & Licensing
Member
GHSgrizzlies
Message 1 of 9 (501 Views)
Maya 2008 license on Mac OS 10.4.11 server
501 Views, 8 Replies
04-02-2012 10:32 AM
I'm at a high school and have 30 floating licenses on an existing server and have been attempting to move the license to another server. I contacted AutoDesk and received a new license file with the Mac Address of the new server, but am having difficulty getting it to run... No matter what I try, Maya will not run on the client machine.
I've checked the online documentation and forums and have not found anything that has directions for Maya 2008 and a server that is OS 10.4. Everything I'm seeing is for more up-to-date software... Any direction or assistance would be great!
Product Support
david.lau
Message 2 of 9 (492 Views)
Re: Maya 2008 license on Mac OS 10.4.11 server
04-03-2012 11:50 AM in reply to: GHSgrizzlies
The update (full installer) can be found here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10535405&linkID=9242259
1.  Mac OS X Server is technically not supported but it *may* work.
2.  I have attached instructions.  You may need to edit the client files.  Syntax is:
SERVER ip-address-of-license-server 7111
USE_SERVER
SERVER  hostname-of-license-server 0 7111
USE_SERVER
David Lau
Member
GHSgrizzlies
Message 3 of 9 (479 Views)
04-04-2012 11:23 AM in reply to: GHSgrizzlies
David,
Thank you so much for your response!! I really appreciate it.
On the server, I installed Autodesk Maya 2008 Service Pack 1 for Mac from the web page then in the Additional Items folder, I installed "Alias_LicenseServer10.8.mpkg" (Should I have done additional installs?)
Then, I followed the directions you supplied, everything seemed to be going great, up until I checked to see if the license was actually running... and I got this message:
lmgrd is not running: Cannot connect to license server system. (-15,570:36 "Operation now in progress")
Any idea what I should do to correct this?
Thanks!!
Product Support
david.lau
Message 4 of 9 (476 Views)
04-04-2012 11:57 AM in reply to: GHSgrizzlies
You need to open the Activity Monitor and kill the sgiawd and lmgrd processes.  There will be a toggle to show all processes.
Then run the start command. i.e. sudo /usr/aw/COM/bin/aw_flexlm start
David Lau
Member
GHSgrizzlies
Message 5 of 9 (468 Views)
04-04-2012 12:57 PM in reply to: GHSgrizzlies
When I looked at all processes in the Activity Monitor, I did see lmgrd and quit that process. But, I did not see sgiawd in the list of processes so I could not quit that... When I checked the license status I got the same message as before.
What else can I do?
Thanks again for your time on this!
Product Support
david.lau
Message 6 of 9 (466 Views)
04-04-2012 01:07 PM in reply to: GHSgrizzlies
Once lmgrd has been quit.  Then start the server again.  Do you have access to a Windows computer?  Licensing setup is MUCH easier.
David Lau
Member
GHSgrizzlies
Message 7 of 9 (463 Views)
04-04-2012 01:26 PM in reply to: GHSgrizzlies
Only a mac server available...
Once I quit lmgrd, I restarted the server and checked Activity Monitor again and lmgrd was running. So I quit it again... Should I have left it running after the restart? (Same message received)
Product Support
david.lau
Message 8 of 9 (460 Views)
04-04-2012 01:43 PM in reply to: GHSgrizzlies
Can you send me an email with you name, phone number and email address?  There is an envelope icon beside the (Sign Out) button.
I would like to help out directly tomorrow.  I work from 9 am to 5 pm EST.
David Lau
Member
GHSgrizzlies
Message 9 of 9 (457 Views)
04-04-2012 01:50 PM in reply to: david.lau
Great. Thanks a lot.
(Just emailed you.)
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
