Installation & Licensing
Max freezes when starting?
2 REPLIES 2
1028 Views, 2 Replies
Hello all,
I posted this issue here, but no one seemed to be able to help, unfortunately, aside from pointing me to these forums.
The gist of the problem is, that Max starts up, and I see the welcome box for student license in the foreground of the program, with everything appearing in the background. I try to click continue, or anywhere else, and it immediately freezes and goes white, and Windows says that it stopped responding, leaving me no choice but to close the program.
Specs:
Vista Home Premium (6.0, Build 6002) 64 Bit, SP2
Intel(R) Core(TM)2 CPU Q6600 @ 2.40 GHz (4 CPUS), ~2.40 GHz
4.094 GB RAM
ATI Radeon HD 3450
DirectX 11
Problem as detailed by Windows:
Description:
A problem caused this program to stop interacting with Windows.
Problem signature:
Problem Event Name: AppHangXProcB1
Application Name: 3dsmax.exe
Application Version: 13.1.4.209
Application Timestamp: 4cedeba2
Hang Signature: f8e7
Hang Type: 33024
Waiting on Application Name: UmxSbxWowHlp.exe
Waiting on Application Version: 1.0.0.3
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 1033
Additional Hang Signature 1: 9eac93d4a6247e5800af1ff2444976f7
Additional Hang Signature 2: 64f7
Additional Hang Signature 3: e7938b08e382231bfeca7795d6c5976f
Additional Hang Signature 4: f8e7
Additional Hang Signature 5: 9eac93d4a6247e5800af1ff2444976f7
Additional Hang Signature 6: 64f7
Additional Hang Signature 7: e7938b08e382231bfeca7795d6c5976f
I've tried everything suggested in the thread linked in the beginning. My driver's are updated, etc. Can anyone help?
Tags (2)
2 REPLIES 2
nikolasns
Please help us , same problem here !!!! generally cant startup a 64bit 3dmax 2009 - 2010
sistem - windows 7
graphic card ati radeon hd 4800
with the same configuration I used this max for a year, but from today is not working...
TravisNave
If you have Computer Associates (CA) anti-virus or firewall installed, either disable it or make an exception for your Autodesk software.
Autodesk Forums:
Administrator Productivity
