Installation & Licensing
Product Support
Message 1 of 13 (4,462 Views)
Matchmover 2012 Standalone with Maya 2012 Standalone - Error [-1359.2]
4462 Views, 12 Replies
04-13-2011 01:59 PM
When you launch Matchmover 2012 Standalone, you may get this error:
A valid license could not be obtained by the network license manager.
If you are still unable to access a license, contact your system administrator.
Error [-1.359.2]
To solve this problem, you will need to copy the License.env file from the Maya application folder into the Matchmover application folder.
  1. Applications > Autodesk > Maya2012 > right click on Maya and select ‘Show package contents’ > Contents > Copy License.env.
  2. Applications > Autodesk > MatchMover2012 > right click on Matchmover2012 and select ‘Show Package Contents’ > Contents > Paste the License.env.
David Lau
New Member
canicetti
Message 2 of 13 (2,992 Views)
Re: Matchmover 2012 Standalone with Maya 2012 Standalone - Error [-1359.2]
11-16-2011 10:07 PM in reply to: david.lau
Thanks!  Worked great!
New Member
Message 3 of 13 (2,018 Views)
04-04-2012 08:04 PM in reply to: david.lau
this also worked perfectly for me and was very simple and easy to follow your instructions. thanks.
New Member
Message 4 of 13 (1,817 Views)
05-02-2012 09:15 AM in reply to: david.lau
Thank you very much! This worked like a charm.
New Member
Message 5 of 13 (1,379 Views)
08-08-2012 08:40 AM in reply to: david.lau
It did not work with Maya 2013 for Mac OS X.
New Member
Message 6 of 13 (1,326 Views)
08-14-2012 01:31 PM in reply to: david.lau
I couldnt get it to work for Match Mover 2013 on OSX either ?  : (
Active Member
Message 7 of 13 (1,308 Views)
08-15-2012 01:25 PM in reply to: david.lau
Getting this same error message in an installation of the ADA achedemic suite. Please reccomend a solution transferable to this software.
New Member
Message 8 of 13 (1,299 Views)
08-16-2012 06:47 AM in reply to: david.lau
does anyone know how to fix this so i can actuallly use Matchmover 2013?
Product Support
Message 9 of 13 (1,297 Views)
08-16-2012 06:59 AM in reply to: david.lau
Just an update that there appears to be an issue with Matchmover 2013 on the Mac.  The development team is aware of the issue.
Please stay tuned.....
David Lau
New Member
Message 10 of 13 (1,213 Views)
Matchmover 2013 no fix
08-23-2012 08:37 AM in reply to: david.lau
It didn't work with Matchmover 2013,  any news on when this is going to be fixed?
Thanks so much!
(Just bought the software)
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
