The procedure entry point ?_Getcat@?$codecvt... ...could not be located in the dynamic link library ..\Setup\LiteHtml.dll
I've been working with Autodesk for a week on this problem but nothing has worked. Have searched the forums and see it is a somewhat common problem but cannot see where there is a clear solution. Has there been a solution found?
Solved by eric. Go to Solution.
Start here:
Solution - Wanted to post an actual solution to this common problem. After fighting this for weeks and getting the same stale non-fixes from Autodesk folks, I was helped by Zach Scott at PacfiCAD. In this instance I was installing AutoCAD 2015 Map3D on a Windows 8.1 64-bit system.
The fix to the Autocad installer program error is to run the setup.exe in Windows XP SP3 compatibility mode as Administrator. Get the install files on your computer and then right click on the setup executable to find the compatiblity tab etc.
fantastic fix! i was struggling with the for days.
Change compatibilty to windows XP service pack 3
Run as administrator!
so easy but would have never have thought it thank you
