I am taking over the CAD Management Roll for a new Company. When I was in the channel I know Autodesk use to use SAM for reporting and being able to tell who has what. We have Seats of Electrical, Vanillia AutoCAD, Factory Design, Product Design and a couple others. As usal they do not have enough seats for all of the new people they are hiring. I need a good way to track who has what and what the peaks are looking like.
Question #1: What is the most acurate and reliable way to see this info now that SAM is gone?
Question #2: What does it take to set up if it has to be set up?
I gotta give props to a fellow board member here with an excellent program that does this in place of the deprecated SAMreport. Check out Jimmy's JTB Flexreport here:
http://www.jtbworld.com/jtbflexreport/index.htm
You can contact Jimmy thru the boards here:
http://forums.autodesk.com/t5/notes/privatenotespage/tab/compose/note-to-user-id/405101
there is also this: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=10243574
this doesn't tell you the peak of usage
DarrenP
