Installation & Licensing
TravisNave
Message 1 of 10 (11,510 Views)
Managing the adskflex.opt Options File
11510 Views, 9 Replies
07-01-2011 02:50 PM
Issue:  You want to configure different licensing options for different user groups and networked licensed products using your Autodesk Network License Manager.
Solution: There is a way to manually configure the Autodesk Network License Manager to use different configurations for each license type, user, group, etc.  You need to create an Options file as instructed in the License Administration Guide.  Your options file should be created in a plain text editor like Notepad and must be named adskflex.opt.  Please ensure that file extensions are enabled so that you do not have a hidden .txt file extension appended to your filename.  Furthermore, the adskflex.opt options file must be saved in the same location as your Autodesk .lic license file.  To activate the options file, you need to reread the license from the Start/Stop/Reread tab of LMTOOLS.  You can then use your debug.log file to verify that the options are working properly.
Additional information about the adskflex.opt Options File can be found here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7459915&linkID=9240617
Creating and Implementing the adskflex.opt Options File
1.  To create an options file, simply open a plain text editor like Notepad and type the options that you wish to implement.
2.  Make sure you then save the file as adskflex.opt and in the same location as your Autodesk *.lic file.  You will want to pull down the save type box to all files so that it will not save with a .txt extension.  Make sure file extensions are enabled to determine if a .txt has been appended. If so, simply rename the file as appropriate.
3.  Open LMTOOLS and go to the Start/Stop/Reread tab and choose ReRead License File.  This will enable the options file that you just saved.
4.  You can verify that the options file is active by viewing the debug.log file.  You can do this from the Config Services tab in LMTOOLS by clicking View Log... or by opening the debug.log file in Notepad from the path specified on the Config Services tab.  You should see log entries for each successful option that you created.  Entries should look similar to the following:
16:52:45 (adskflex) Using options file: "C:\Program Files\Autodesk Network License Manager\License\adskflex.opt"
16:52:45 (adskflex) ALL FEATURES: INACTIVITY TIMEOUT set to 900 seconds
16:52:45 (adskflex) Max borrow interval for feature, 64300ACD_F , set to 48 hours
16:52:45 (adskflex) RESERVING 1 64300ACD_F  license for USER_GROUP Admins
16:52:45 (adskflex) MAX 1 USER_GROUP Users for 64300ACD_F
16:52:45 (adskflex) INCLUDE USER_GROUP Admins 64300ACD_F
16:52:45 (adskflex) Report log started (+C:\Program Files\Autodesk Network License Manager\report.rl).
You can use the adskflex.opt options file to split licenses into different groups, reserve licenses for power users, or limit the amount and time licenses can be borrowed.  For details on each available option, please see the License Administration Guide in the documentation of your Autodesk Network License Manager or from the Autodesk KB link provided above.
Feature codes for each of your licensed products can be found within the PACKAGE and INCREMENT lines of the .lic license file provided by Autodesk.  A list of Autodesk 2012 feature codes can be found here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17288427&linkID=9243099
For your convenience I am attaching a ready-made adskflex.opt options file that includes all of the available compatible options for the Autodesk Network License Manager along with commented descriptions and examples. You can use this file as a starting point to create your own customizations.  Please unzip the file and edit with Notepad.
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
TravisNave
Message 2 of 10 (11,493 Views)
Re: Managing the adskflex.opt Options File
07-01-2011 02:55 PM in reply to: TravisNave
The License Administration Guide for the FlexLM can be found at the following link:
http://www.globes.com/support/utilities/fnp_LicAdmin_11_9_1.pdf
Please see chapter 13 regarding the Options File.
matthew.roberts
Message 3 of 10 (5,760 Views)
04-11-2013 04:57 AM in reply to: TravisNave
hi
having trouble with Building Design Suite 2013 and borrowing licences .... i have created an adskflex option file.
and have confirmed the option file is being read by lmtool/flexlm.
i am the only user id in the borrowcad group ; however other users are still able to borrow licences even tho they are not included in the group. Have i missed something ?
options file :-
#options file matt 02/04/2013
GROUP BorrowCad camsr1
TIMEOUTALL 900
# Building Design Suite Standard
BORROW_LOWWATER 85947BDSS_2013_0F 1
INCLUDE_BORROW 85947BDSS_2013_0F GROUP BorrowCad
#Building Design Suite Premium
BORROW_LOWWATER 85946BDSPRM_2013_0F 1
INCLUDE_BORROW 85946BDSPRM_2013_0F GROUP BorrowCad
Do i need to individually add all features codes in the suite ? and assign the BorrowCAD group?
any help appreciated
regards
Matt
TravisNave
Message 4 of 10 (5,758 Views)
04-11-2013 05:12 AM in reply to: matthew.roberts
You need to add the option GROUPCASEINSENSITIVE ON to your list. That
should allow it to work.
New Member
miguel.aldama
Message 5 of 10 (4,391 Views)
09-04-2013 04:02 PM in reply to: TravisNave
I have 8 license for Autodesk Product Desing Suite Standar 2014, but we just use the ACAD Mechanical 2011 (beacuse our standard)...
But we want to have 1 licenese reserved for a group of 2 users, and another license for another 2 users... the remaining 6 license wil be available for the rest of the users.
This is the option file so far:
GROUP Engineering jdelacru ichavez
GROUP ProductEng egarcia1 joliver
RESERVE 1 85813PDSS_F GROUP Engineering
RESERVE 1 85813PDSS_F GROUP ProductEng
But, at todays license usage, I notice that egarcia1 and joliver can have 2 license opened at the same time, is it possible to isolate this license just for one of them at the time? I mean, if egarcia1 has the ACAD open, then joliver has to wait until the license is released.
Another question is, the users only opens AutoCAD Mechanical 2011, is it correct to add this feature code only? 85813PDSS_F ?
How can I configure the rest of the users to look only for the 6 remaining license on the pool?
Thank you very much for the help!:smileyhappy:
TravisNave
Message 6 of 10 (4,378 Views)
09-05-2013 09:06 AM in reply to: miguel.aldama
Welcome to the community.
Excellent questions.  I believe what you are asking can be done with some tweaking.
You can limit the group to the 1 license by using the MAX option.  Here's what I recommend for your options file syntax:
TIMEOUTALL 900
MAX 1 85813PDSS_F GROUP Engineering
MAX 1 85813PDSS_F GROUP ProductEng
This would still reserve the 2 licenses (effectively leaving the 6 for everyone else *not* on the group list.)  But it would also limit the groups to 1 license max each.  So if egarcia1 is using AutoCADM, then joliver will get denied until that one reserve is freed up.  Nobody else would be denied unless the 6 remaining are used up.  I always recommend the TIMEOUTALL option because it will help return idle licenses should somebody launch the program and then leave it up all day and not use it.
Also, it might be a good idea to consider the EXCLUDE_BORROW option for those groups as well, because of egarcia1 borrows a seat, then joliver will never be able to launch it, until it expires.  Just a thought.
As for your feature code, it's best to reserve with the PDSS_F because it reserves the whole Subscription package, rather than just the Mechanical.  So, you're fine there.
Make the changes, stop/start the service, and verify in the debug.  Hope that helps!
New Member
scf4444
Message 7 of 10 (4,020 Views)
10-15-2013 03:44 PM in reply to: TravisNave
Is it possible to limit the max usage of one of the software titles within the Building Design Suite?  For example, in a 10-user network license, can AutoCAD be prevented from consuming more than 4 BDS network licenses?  Can it be done without having to define and maintain a group in the options file?
Thanks!
TravisNave
Message 8 of 10 (3,998 Views)
10-16-2013 08:06 AM in reply to: scf4444
This is a tough question.  You might be able to do it with a MAX option on your entire subnet.
MAX 4 86063ACD_2014_0F INTERNET 192.168.1.*
Limiting cascade is not any easy thing to do in partial.  It's typically all or none.  But you might be able to experiment and get something figured out.
GTVic
Message 9 of 10 (916 Views)
06-06-2014 01:10 PM in reply to: TravisNave
Hi Travis,
Is it possible to break the HOST_GROUP <name> <computer1> <computer2> ... line into multiple lines?
Greg
TravisNave
Message 10 of 10 (914 Views)
06-06-2014 01:17 PM in reply to: GTVic
Yes, the line is infinite so wordwrap doesn't mean anything.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
