Installation & Licensing
Major headache installing autocad
1 REPLY 1
307 Views, 1 Reply
My installation of autocad (student licence) consistently fails.  I have tried a number of things including running as administrator and now going so far as to reinstall windows.  It worked fine for a period of time and then seemed to just stop working.  Ever since then I have been unable to install.  I get to the installation procedure but it fails every time.  I have copied the install log:
2012/4/18:13:33:23 Administrator LAPTOPFROMHELL === Setup started on LAPTOPFROMHELL by Administrator ===
2012/4/18:13:33:23 Administrator LAPTOPFROMHELL Launch
2012/4/18:13:34:47 Administrator LAPTOPFROMHELL === Setup ended ===
2012/4/18:13:33:24 Administrator LAPTOPFROMHELL === Setup started on LAPTOPFROMHELL by Administrator ===
2012/4/18:13:33:24 Administrator LAPTOPFROMHELL Launch
2012/4/18:13:34:50 Administrator LAPTOPFROMHELL PageOpen LaunchDialog
2012/4/18:13:37:28 Administrator LAPTOPFROMHELL PageOpen LicenseDialog
2012/4/18:13:37:32 Administrator LAPTOPFROMHELL PageOpen ProductInfoDialog
2012/4/18:13:37:37 Administrator LAPTOPFROMHELL PageOpen ProductSelectionDialog2
2012/4/18:13:37:44 Administrator LAPTOPFROMHELL PageOpen FullProgressDialog
2012/4/18:13:37:44 Administrator LAPTOPFROMHELL Installing Autodesk® Design Review: TRANSFORMS="C:\Users\ADMINI~1\AppData\Local\Temp\_AIC5E.tmp\x86\en-us\Components\adr2012\SetupDesignReview2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/18:13:38:17 Administrator LAPTOPFROMHELL Install Autodesk® Design Review Succeeded
2012/4/18:13:38:17 Administrator LAPTOPFROMHELL Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/4/18:13:39:20 Administrator LAPTOPFROMHELL Install DirectX Runtime Succeeded
2012/4/18:13:39:20 Administrator LAPTOPFROMHELL Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/18:13:39:43 Administrator LAPTOPFROMHELL Install FaroSDK Succeeded
2012/4/18:13:39:43 Administrator LAPTOPFROMHELL Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/18:13:40:03 Administrator LAPTOPFROMHELL Install Autodesk Material Library 2012 Succeeded
2012/4/18:13:40:03 Administrator LAPTOPFROMHELL Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/18:13:40:36 Administrator LAPTOPFROMHELL Install Autodesk Material Library 2012 - Low Resolution Succeeded
2012/4/18:13:40:36 Administrator LAPTOPFROMHELL Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/18:13:40:52 Administrator LAPTOPFROMHELL Install Autodesk Content Service Succeeded
2012/4/18:13:40:53 Administrator LAPTOPFROMHELL Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\ADMINI~1\AppData\Local\Temp\_AIC5E.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/18:13:41:18 Administrator LAPTOPFROMHELL Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2012/4/18:13:41:28 Administrator LAPTOPFROMHELL Rollback Autodesk Content Service Succeeded
2012/4/18:13:41:40 Administrator LAPTOPFROMHELL Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2012/4/18:13:41:54 Administrator LAPTOPFROMHELL Rollback Autodesk Material Library 2012 Succeeded
2012/4/18:13:41:58 Administrator LAPTOPFROMHELL Rollback FaroSDK Succeeded
2012/4/18:13:41:58 Administrator LAPTOPFROMHELL Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/4/18:13:42:11 Administrator LAPTOPFROMHELL Rollback Autodesk® Design Review Succeeded
This is now a real issue as I have stacks of drawings to do for my college project,  Any help will be very, very gratefully recieved:
Nick
1 REPLY 1
Good luck. I've filed countless automated TPS reports and posted in the forums and I think they are all on vacation.
Administrator Productivity
