Installation & Licensing
New Member
piechciu
Message 1 of 6 (695 Views)
Accepted Solution
MOLDFLOW ACTIVATION PROBLEM
695 Views, 5 Replies
07-24-2011 02:15 AM
I have moldflow adviser 2012 sudents ver. and i've problem with licence.
How do I activate the product
Please help
This program do I need to write engineering work
krzysztof
Product Support
hashim.mundol
Message 2 of 6 (659 Views)
Re: MOLDFLOW ACTIVATION PROBLEM
08-01-2011 12:02 AM in reply to: piechciu
Did you follow the instructions here
http://students.autodesk.com/ama/orig/MoldflowAdviser2012NLMInstallGuide.pdf
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
New Member
autodesk
Message 3 of 6 (607 Views)
10-04-2011 08:50 AM in reply to: hashim.mundol
Having problems getting Moldlfow Student version licensed and came upon this thread. I hope you don't mind me butting in.
In those instructions above it says;
"Product Registration
To obtain the full 36 month license, Autodesk Moldflow Adviser must be registered. To register select:
Start > All Programs > Autodesk > Autodesk Moldflow Adviser 2012 > Autodesk RegisterOnce
Follow the instructions on the web page that opens."
The problem is the instructions on that page are not very clear! The registration page takes me to a page that requests "Server 1 host name:" and "Server 1 ID" in order to generate the license file. What should I use for "Server 1 host name" - LOCALHOST, 127.0.0.1, or the real name of my computer?  And for "Server 1 ID", do I use the MAC address of a network connection on my machine? If I choose the wireless connection which is active at the moment,will the license server still work when it is inactive and I am connected by LAN?
Product Support
hashim.mundol
Message 4 of 6 (601 Views)
10-05-2011 02:28 AM in reply to: autodesk
Actual Computer name and the mac address as host ID would be needed
Mac address should be visible to the license manager software for the license to work. (you can check this using LMTOOLS, installed as part of the license manager)
So if wireless card is not disabled during the wired LAN operation you can use that.
Hashim Mundol
Autodesk, Inc.
New Member
autodesk
Message 5 of 6 (599 Views)
10-05-2011 03:36 AM in reply to: hashim.mundol
Thanks. For clarity - Computer/Hostname and Ethernet (MAC) Address are listed under the "System Settings" tab of LMTOOLS.
127.0.0.1 also works as hostname.
These instructions should really be included in the install guide MoldflowAdviser2012NLMInstallGuide.pdf you are directing people to or else linked to elsewhere. Most students would not have experience of setting up a FlexLM license server (as simple as it is once you know how).
Product Support
hashim.mundol
Message 6 of 6 (586 Views)
10-06-2011 01:06 AM in reply to: autodesk
Thank you for the recommendation, We will  recommend the relevant team to add reference to the license manager in the docs.
Hashim Mundol
Autodesk, Inc.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
