Laptop battery died while installing. Now when I try to reinstall I get an error. Below is what I found in the message log.
Install Flash Failed Failure is ignored, Result=1
Install Autodesk Architectural Desktop 2007 Failed Installation aborted, Result=1603
Solved by TravisNave. Go to Solution.
Welcome to the community.
I assume you are installing on Windows XP, being that the software is so dated.
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP only consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Good Luck!
