• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Lowrance, Tim
    Locked file
    100 Views, 5 Replies
    11-12-1999 05:40 PM
    <<< Message <382C7AEE.6F403CA1@Miinc.net> was originally posted to 'autodesk.autocad.2000general' on Fri, 12 Nov 1999 14:39:10 -0600.>>>
    This is an R14 question because we're still using it here. I have a dwg
    file on the network (Novel) that cannot be deleted or renamed. The
    messages say there is another application that has a portion of the file
    locked. However, no one in the company has that particular file open.
    I can open it as read only and save it back as another name, but then
    I'd have to open 25 other drawings that use it as an xref drawing. Got
    any ideas?
    TL
    Please use plain text.
    *Pool, Michael
    Re: Locked file
    11-12-1999 05:40 PM in reply to: *Lowrance, Tim
    <<< Message <80iasb$seb15@adesknews2.autodesk.com> was originally posted to 'autodesk.autocad.2000general' on Fri, 12 Nov 1999 16:20:25 -0800.>>>
    What operating system? Network?
    Tim Lowrance wrote in message
    news:382C7AEE.6F403CA1@Miinc.net...
    > any ideas?
    > TL
    *Lowrance, Tim
    Re:
    11-15-1999 05:08 AM in reply to: *Lowrance, Tim
    Novell 5.0
    TL
    > > any ideas?
    > > TL
    *Canter, Gigi
    Re:
    11-29-1999 01:14 PM in reply to: *Lowrance, Tim
    We have the same issues going on and we are using Novell 4.1 with 3.1.0.5
    SP1 client. Our workstations are W95b and we are using Acad R14.01 with
    local installations and network (IPX) license management.
    Gigi Canter
    CADD Administrator
    Seattle Public Utilties & Seattle Transportation Department
    Tim Lowrance wrote in article
    <383005E7.6D48C926@Miinc.net>...
    > Novell 5.0
    > TL
    *Dutka-Menges, B.
    Re:
    12-02-1999 11:28 AM in reply to: *Lowrance, Tim
    Upgrade your client to SP2 and make sure you apply the server side file
    locking patch. (REVFHRFT.EXE.). Do a search at support.novell.com and then
    apply this. Worked for us.
    Gigi Canter wrote in message
    news:01bf3aae$b5fde8a0$cefd4a9c@spu3392...
    > Gigi Canter
    > CADD Administrator
    > > Novell 5.0
    > > TL
    *Curl
    Re:
    05-23-2000 08:42 PM in reply to: *Lowrance, Tim
    this has happen to me several times using novell 3 to 5.0. a user or computer did not disconect from server correctly so server still has it locked.
    if you go through novell conection to see who is on and what they have open. you will find the person that has the file. kill the conection on server
    and then you will be able to rename or delete the file.
    normal should release the file after 15 minutes or so i have seen a file be lock for four days!!!
    > > any ideas?
    > > TL
