Installation & Licensing
*Lowrance, Tim
Message 1 of 6 (134 Views)
Locked file
134 Views, 5 Replies
11-12-1999 05:40 PM
<<< Message <382C7AEE.6F403CA1@Miinc.net> was originally posted to 'autodesk.autocad.2000general' on Fri, 12 Nov 1999 14:39:10 -0600.>>>
This is an R14 question because we're still using it here. I have a dwg
file on the network (Novel) that cannot be deleted or renamed. The
messages say there is another application that has a portion of the file
locked. However, no one in the company has that particular file open.
I can open it as read only and save it back as another name, but then
I'd have to open 25 other drawings that use it as an xref drawing. Got
any ideas?
TL
*Pool, Michael
Re: Locked file
11-12-1999 05:40 PM in reply to: *Lowrance, Tim
<<< Message <80iasb$seb15@adesknews2.autodesk.com> was originally posted to 'autodesk.autocad.2000general' on Fri, 12 Nov 1999 16:20:25 -0800.>>>
What operating system? Network?
Tim Lowrance wrote in message
news:382C7AEE.6F403CA1@Miinc.net...
> any ideas?
> TL
*Lowrance, Tim
Message 3 of 6 (134 Views)
Re:
11-15-1999 05:08 AM in reply to: *Lowrance, Tim
Novell 5.0
TL
> > any ideas?
> > TL
*Canter, Gigi
Message 4 of 6 (134 Views)
Re:
11-29-1999 01:14 PM in reply to: *Lowrance, Tim
We have the same issues going on and we are using Novell 4.1 with 3.1.0.5
SP1 client. Our workstations are W95b and we are using Acad R14.01 with
local installations and network (IPX) license management.
Gigi Canter
CADD Administrator
Seattle Public Utilties & Seattle Transportation Department
Tim Lowrance wrote in article
<383005E7.6D48C926@Miinc.net>...
> Novell 5.0
> TL
*Dutka-Menges, B.
Message 5 of 6 (134 Views)
Re:
12-02-1999 11:28 AM in reply to: *Lowrance, Tim
Upgrade your client to SP2 and make sure you apply the server side file
locking patch. (REVFHRFT.EXE.). Do a search at support.novell.com and then
apply this. Worked for us.
Gigi Canter wrote in message
news:01bf3aae$b5fde8a0$cefd4a9c@spu3392...
> Gigi Canter
> CADD Administrator
> > Novell 5.0
> > TL
*Curl
Message 6 of 6 (134 Views)
Re:
05-23-2000 08:42 PM in reply to: *Lowrance, Tim
this has happen to me several times using novell 3 to 5.0. a user or computer did not disconect from server correctly so server still has it locked.
if you go through novell conection to see who is on and what they have open. you will find the person that has the file. kill the conection on server
and then you will be able to rename or delete the file.
normal should release the file after 15 minutes or so i have seen a file be lock for four days!!!
> > any ideas?
> > TL
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
