I have Successfully managed to Deploy through SMS and Use
AutoCAD2000i as a Restricted User on Windows 2000. I did
have to make some minor changes to the ACAD.msi in the IMAGE folder to
tailor the Install for our environment but
that was it. Below are the Registry Keys and Folder Permission required to
get it working as a User. This is how I got it working but as usually take a
backup of the Registry before you try anything - I don't accept
responsibility if anything should go wrong.
Registry
HKCR\CLSID\{8E75D913-3D21-11d2-85C4-080009A0C626} - Full Control to User
HKCR\CLSID\{83836783-4E7A-11D3-8300-0060B0EF5B11} - Full Control to User
HKCR\AutoCAD.Drawing.15 - Full Control to User
HKCR\AutoCAD.Drawing - Full Control to User
HKLM\SOFTWARE\Autodesk - Full Control to User
Files/Folders
"%SystemDrive%\Program Files\AutoCAD 2000i\Sample - Full Control to User
"%SystemDrive%\Program Files\AutoCAD 2000i - Write/Read/Execute Control to
User
"Paul Johnson"
wrote in message
news:f139e04.0@WebX.maYIadrTaRb...
> I should also tell you that i an using Windows20000 with AutoCAD 2000i
