Robert,
lmborrow will be on the workstation, not the server.
Jerry
"R. Robert Bell" wrote in message
news:4149e78e$1_2@newsprd01...
> I cannot find lmborrow.exe anywhere on the server.
> Server: Wn2k SP4
> WS: WinXP Pro SP1
> The user is gone once again, along with his laptop.
> R. Robert Bell
> "jerry milana (Autodesk Consulting)" wrote in
message
> news:4148d39d$1_3@newsprd01...
> Go to the Utilities tab of LMtools and use the browse button to select
> c:\program files\common files\autodesk shared\lmborrow.exe
> then select to check the FLEXlm version of this file. Let us know the
> version of this file. Also please advise us of the OS and service pack
> level at the workstation and server.
> To make sure that the workstation can still communicate with your license
> managers, log in as a user other than the person who borrowed the license.
> Since borrowed licenses are specific to users so Acad will try to get a
> license from the server.
> news:4148b839$1_2@newsprd01...
> > AdskFlex_License_File=@HOMER;@BART
> > Distributed
> > R. Robert Bell
> message
> > news:41489e5d$1_3@newsprd01...
> > Robert,
> > Early return problems can be caused by the method you use to point to
> > license servers. Do you use licpath.lic or the ADSKFLEX_LICENSE_FILE
> > variable to resolve license servers? Also how many license servers do
you
> > have and if you have more than one server are they configured in
redundant
> > or distributed mode?
> > Jerry Milana,
> > Autodesk Consulting
> > news:41487745$1_1@newsprd01...
> > > The error I get on the user's laptop is:
> > > "Your license cannot be returned. For more information, contact your
> > system
> > > administrator. Can still use until Friday, 17 September 2004. Error:
> > > [1200.5.-96]
> > > R. Robert Bell
> > > news:41485952$1_2@newsprd01...
> > > Jerry,
> > > As luck would have it, that engineer showed up in the office today. I
> had
> > > him try to return the borrowed license, but it failed to return. Also,
I
> > > have noticed that the linger value on the server has not changed.
Today
> it
> > > still shows 2277480 seconds. Any ideas?
> > > R. Robert Bell
> > message
> > > news:41474296$1_2@newsprd01...
> > > TIMEOUT has no effect on borrowed licenses, only licenses that are
> checked
> > > out for a session work with TIMEOUT. Yes, the linger parameter is the
> > > remaining time left on the borrow in seconds. After that amount of
time
> > the
> > > borrow will expire on jasons and become available on the server again.
> > > There is now way to force early return even if the workstation is
> > connected.
> > > Early return must be performed on the workstation that borrowed the
> > license
> > > by the user that borrowed the license and of course, the workstation
> will
> > > need to be connected to the network at the time of early return.
> > > Jerry Milana,
> > > Autodesk Consulting
