• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    eaus
    Licensingserver for AutoCAD 2011
    183 Views, 5 Replies
    09-01-2011 03:54 PM
    Hi.
    We are currently in a situation where our AutoCAD licensing server has to be moved, and upgraded to support the latest version.
    As far as I know we have a 10 user limit license.
    A few weeks ago I received the new AutoCAD 2011 DVD in the mail and my questions are basically... What do I do? Where do I start?
    I am totally new to AutoCAD and I am reluctant to spend too much time and effort on it, so hopefully I can get some good starting pointers here :smileyhappy:
    Please use plain text.
    TravisNave
    Re: Licensingserver for AutoCAD 2011
    09-01-2011 06:48 PM in reply to: eaus
    First think you need to do is obtain your new license file. 1-800-551-1490. Then update your NLM server files and point it to your new license file. At that point simply install your clients as network versions. If you need more details let me know.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    eaus
    09-02-2011 12:20 AM in reply to: TravisNave
    Hi.
    How should I go about moving the current license server? From what I can remember we tried this once before without any sucsess.
    TravisNave
    09-02-2011 07:42 AM in reply to: eaus
    You're not really going to move it, per se.  The LIC file on the old server won't work on the new one.  All you really need to do is install the license manager from your 2011 media on the new server and get the license file from Autodesk Activations.
    Then you can install your clients and point to the new server.  It's easier than you think.
    If there's anything you get stuck on just let me know.
    Travis Nave
    Member
    eaus
    09-02-2011 08:24 AM in reply to: eaus
    Will it be backwards compatible with e.g.AutoCAD 2008?
    Thanks for your help, i deeply appreciate it!
    TravisNave
    09-02-2011 08:44 AM in reply to: eaus
    Yes.  The NLM is backwards compatible to version 9.2, which I believe is AutoCAD 2004 if my memory serves correct.  If your 2011 product is under Subscription, your new subscription license file should allow for use of AutoCAD 2008, 2009, 2010, and 2011.
    Autodesk does provide a too long explanation how-to video on the NLM here:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13503006&linkID=9240697
    Travis Nave
