Get the following error when performing status enquiry in lmtools 11.4.100.0 with the supplied license file.
Status
Flexible License Manager status on Fri 8/20/2010 13:22
[Detecting lmgrd processes...]
License server status: 27000@appv11
License file(s) on appv11: C:\FlexLM\license.dat:
appv11: license server UP (MASTER) v11.4
Vendor daemon status (on appv11):
adskflex: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Vendor:Host: appv11
License path: 27000@appv11;
FLEXnet Licensing error:-97,121
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
Any ideas?
Please check the solution
http://usa.autodesk.com/getdoc/id=TS13587543
any other error in debug log ?
No, but I did notice this appears as part of a status enquiry
my license file is stored in c:\flexlm\maya.lic and the software is configured to read it from here so why does the status enquiry show it as being somewhere else?
Normally
C:\FlexLM\license.dat would be the license file
C:\FlexLM\maya.lic would be path (name and port) to the license server.
Please check in lmtools how it is configured.
As I said, the software is configured to read the c:\flexlm\maya.lic license file.
did you try to re-read the license file,?
is Ignore Env. Variable is ticked in LMTOOLS?
Was this working before.? what changes were made.
re-reading the license file fails every time.
ignore path environmental variables is not ticked, should it be?
The problems started when I installed a new version of flexlm to host the new license file for Maya 11.
Yes Please tick that
also you can try with the new version of flexlm 11.7 (with the ipv6 patch if you have ipv6)
Installed 11.7 - still get the following
Status
Flexible License Manager status on Fri 8/20/2010 15:27
License server status: @appv11
License file(s) on appv11: C:\FlexLM\maya.lic:
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: appv11
License path: @appv11;
FLEXnet Licensing error:-15,570
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com"
can you ping appv11
please Add lmgrd.exe and adskflex.exe in the DEP exception.
do you have you have firewall clocking these ports (27000-27009 and 2080)
try to use ip address in the license file instead of name
Do you have ipv6 enabled on the machine ? if yes, disable or install patch.
I am remotley connected to appv11 so it is definatley pingable
We don't have internal firewalls so no blocked ports
What and where is the DEP exception?
I can use appv11's ip address but I can ping appv11 and remotley connect to appv11 so I don't think it's a DNS problem
http://support.microsoft.com/kb/875352
SORTED!!!!
Thanks ever so much for your help!
I thought I'd read the installation doc but can't remember seeing anything about DEP exceptions.
Thanks again!
Vendor:Host: CENTRALLAB
License path: 27000@CENTRALLAB;
available at "www.acresso.com".
Make sure your ports 27000 and 2080 are open. If you are on Server 2008 R2 or newer, you might consider using NLM version 11.7.
