Installation & Licensing
New Member
namonok
Message 1 of 2 (174 Views)
Licensing Studio 2012 on Macintosh OS X 10.6.8
174 Views, 1 Replies
09-22-2011 03:19 PM
I downloaded and installed Surface 2012 for Macintosh. The install went fine but it cannot find a license from my license server.
I entered the server name, serial # and product code. On starting the app I get the following:
A valid license could not be obtained bt the Network license manager, Error [-97.121.0]
My Windows workstations do not have a problem getting licenses.
Anyone has any  thought oon what may be causing this.
Product Support
david.lau
Message 2 of 2 (155 Views)
Re: Licensing Studio 2012 on Macintosh OS X 10.6.8
09-26-2011 09:45 AM in reply to: namonok
Go here:
http://forums.autodesk.com/t5/Installation-Licensing/Installing-Maya-2011-2012-with-a-Network-licens...
Note #7
7.  If you have installed Maya/Studio on the same computer as the license server, there may also be a /var/flexlm/######.lic file.   To easily edit the file in the /var/flexlm folder, you will need to run this command:
sudo chmod -R 777 /var/flexlm
<enter>
=Full permissions on this folder.  You can then edit the license file using Textedit and saving in the same folder without any permissions issues.
The maya.lic file should contain:
SERVER your-server-name-or-ip-address 0
USE_SERVER
NOTE:  There should be a the number 0 after your-server-name-or-ip-address.
David Lau
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
