I downloaded and installed Surface 2012 for Macintosh. The install went fine but it cannot find a license from my license server.
I entered the server name, serial # and product code. On starting the app I get the following:
A valid license could not be obtained bt the Network license manager, Error [-97.121.0]
My Windows workstations do not have a problem getting licenses.
Anyone has any thought oon what may be causing this.
Go here:
Note #7
7. If you have installed Maya/Studio on the same computer as the license server, there may also be a /var/flexlm/######.lic file. To easily edit the file in the /var/flexlm folder, you will need to run this command:
sudo chmod -R 777 /var/flexlm
<enter>
=Full permissions on this folder. You can then edit the license file using Textedit and saving in the same folder without any permissions issues.
The maya.lic file should contain:
SERVER your-server-name-or-ip-address 0
USE_SERVER
NOTE: There should be a the number 0 after your-server-name-or-ip-address.
