Hello, we are a company that run Maya 2014 with a subscription. Licenses is handled with on a single network manager, and now when we are upgrading to Maya 2015 there has turned up an issue.
We have upgraded the Autodesk License Manager to the latest version, and have generated a license for the new Maya, which is in the correct folder on the server. 2014 still works as expected.
It would be great if anyone could point us in the right direction.
Solved by DarrenP. Go to Solution.
verify you are running Flex LM 11.12
also run your license file through here to verify there is a Maya 2015 license in it
DarrenP
Thank you!
Yes, "subscription package Autodesk Maya", 2015 included in the list. And I can comfirm that the we are running 11.12
run a status inquiry in Flex LM and verify its up and running
DarrenP
I have used the demo version of Maya 2015 and after subscribing I am am getting the license issues listed above.
Can anyone walk me through what I nerd to do. I am unsure how to check the Flex LM setup so if someone can help in that regards that would also help.
I have been trying since Wednesday and been online with Autodesk who had be add the subscription updates but I am still having a licensing issue and
cannot run MAay 2015 at all.
