• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    amilovatsug
    Licensing Error Code 110 - AutoCAD and Civil 3D (2010 and 2011)
    8647 Views, 9 Replies
    06-25-2010 04:54 AM
    When I click "Activate" in the Activation dialog box, I get a licensing error with error code 110. This happen with 2010 and 2011 versions of AutoCAD and Civil3D.
    Please, view attachments.
    Thanks.
    P.S.: Stand Alone, Student License
    Please use plain text.
    Product Support
    Re: Licensing Error Code 110 - AutoCAD and Civil 3D (2010 and 2011)
    06-28-2010 02:58 AM in reply to: amilovatsug
    Error 110 means “Error creating a request”.  The problem can be:
    1.       ASR folder was not created during the install.
    2.       Missing ASR files from ASR folder.
    Normally uninstall and reinstall product should help but before doing that you should try to determine if the issue is with a missing ASR folder or with missing ASR files in that folder.  Also, check permissions on the machine.  Does this happen on multiple machines or only one?
    ASR folder path
    Vista/win7 - C:\ProgramData\Autodesk\Adlm\Asr
    Win XP - C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm\Asr
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    Active Member
    amilovatsug
    06-28-2010 06:15 AM in reply to: hashim.mundol
    Your explanation helped me to find the problem.
    The AutoCAD was looking for the path C:\Documents and Settings\All Users\Dados de Aplicativos\Autodesk\Adlm\Asr (translation of Application Data to Portuguese), but the installation has occurred in that folder you told.
    I just copied one folder to another, and the problem has been solved.
    This happened because my old AutoCAD was installed there. Also, a program from Microsoft changed the registry to the English language, causing the confusion.
    Unfortunately, I don't know how to reverse it. I think will give me problem in the future with AutoCAD or other program.
    Thank you.
    P.S.: Sorry about the poor English...
    New Member
    cfitzgib
    07-27-2010 08:08 AM in reply to: amilovatsug
    Hi
       I have received the same error code.  I have tried reinstalling but still get the same error code.   I checked c:\documents and settings\All Users\Application Data\Autodesk\Adlm\Asr.  There are lots of files but can't find any files called  ASR  in this directory. I have a 25 seat stand alone license.
    New Member
    gogola88
    04-27-2012 05:13 AM in reply to: cfitzgib
    Hello, I have the same prolem with AutoCad 2013 on WIn 7 (licensing error 110) , the path to ASR folder is :  C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\acad\Common Application Data Folder \ Autodesk \ AdLM\ASR,
    should I copy the folder to other place ? I have student version
    Member
    08-18-2012 01:37 PM in reply to: amilovatsug
    I know how to fix it
    first,you have to open notepad and type this thing
    Windows Registry Editor Version 5.00
    [HKEY_CLASSES_ROOT\*\shell\runas]
    @="Take Ownership"
    "NoWorkingDirectory"=""
    [HKEY_CLASSES_ROOT\*\shell\runas\command]
    @="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
    "IsolatedCommand"="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
    [HKEY_CLASSES_ROOT\Directory\shell\runas]
    @="Take Ownership"
    [HKEY_CLASSES_ROOT\Directory\shell\runas\command]
    @="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
    "IsolatedCommand"="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
    then save it name Take Ownership.reg
    then click on it and click Yes
    Now you can Unlock folder that have key pic on it
    go to C:\ProgramData
    and right click on Autodesk select Take Ownership
    then refesh.Now you can see the key pic disappear
    do this the same with FLEXNet Folder (same location)
    Install Program again
    Good luck :smileyhappy:
    New Member
    08-27-2012 08:53 AM in reply to: amilovatsug
    All,
    I get this same error after installing Autocad 2013 for Mac on a Macbook Pro.  Any direction on fixing this on an Apple would be appreciated!  I have attached images...
    Thanks!
    Clyne Curtis
    BIM Coordinator
    Brigham Young University
    New Member
    09-20-2012 06:20 AM in reply to: clynecurtis
    Clyne,
    Were you able to find a solution. We are having the same problem.
    Navneet
    University of Manitoba
    New Member
    09-20-2012 08:07 AM in reply to: navneet_sharma
    Not yet...we are thinking it might be an issue with the operating system Mountain Lion which is not yet supported by Autodesk... [cid:image001.jpg@01CD970F.5D90B280]
    New Member
    12-30-2012 05:38 PM in reply to: nachanok_rim
    Thank you nachanok_rim,
    I've tried many many things, found on many forums and couldn't find the anwsers to my problems (same error code, but with maya 2013 and mudbox 2013)
    I did what you said and it worked perfectly, didn't even need to reinstall.
    So i'll try to spread your post on other forums where others seems to have found the same problems.
    Thanks again.
