Installation & Licensing
Darin.Green
Message 11 of 15 (568 Views)
Re: Licensing Error - 96.491.0
08-24-2012 12:09 PM in reply to: PROSEO
You may need a new license file. When changing hardware on a machine the MAC Address also changes. Compare the MAC Address within the license file to your NIC card information. To get the NIC info, go to Start and type “cmd” in the search box. When the command prompt is displayed, type “ipconfig /all”
If the MAC Addresses are different, request a new license file by logging into registeronce.autodesk.com
Hope that helps.
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
Member
PROSEO
Message 12 of 15 (558 Views)
08-24-2012 02:22 PM in reply to: Darin.Green
Thanks Darin,
I checked the MAC addresses and they seem to be the same.
Cheers
Darin.Green
Message 13 of 15 (540 Views)
08-26-2012 07:25 PM in reply to: PROSEO
You may need a new license file. When changing hardware on a machine the MAC Address also changes. Compare the MAC Address within the license file to your NIC card information. To get the NIC info, go to Start and type “cmd” in the search box. When the command prompt is displayed, type “ipconfig /all” If the MAC Addresses are different, request a new license file by logging into registeronce.autodesk.com Hope that helps. [cid:imagef05e29.GIF@0b1ae091.4598edd5] Darin Green AEC Support Specialist 472 California Road | Quakertown, PA 18951 Main Office: 800-836-5440 Direct Dial: 215-302-3000 Fax: 215-302-3001www.synergis.comFacebook | Twitter | LinkedIn | YouTube Synergis Achieves Platinum Status, Autodesk’s Highest Tier for VARs This email and any attachments are intended only for the person or entity to which it is addressed and may contain information which is confidential, privileged or otherwise protected from disclosure. Distribution or copying of this email or the information contained herein by anyone other than the intended recipient is prohibited. If you have received this email in error, please immediately notify the sender by return email and please delete and destroy this email and any attachments.
Darin Green
Member
PROSEO
Message 14 of 15 (491 Views)
09-26-2012 09:43 AM in reply to: Darin.Green
We didn´t change the hardware in the machine. What we got is a new router from our internet provider because the one we had stopped working. It is very strange that it worked the other day and now its back to having the same error. We need help!
Darin.Green
Message 15 of 15 (486 Views)
09-26-2012 10:34 AM in reply to: PROSEO
Proseo,
Check to see if your firewall is enabled. If so, disable it and try running the application again.
Darin Green
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
