Installation & Licensing
joeltsack
Message 1 of 14 (994 Views)
Licensing Error [-4.132.0] PDSU 2013
994 Views, 13 Replies
07-03-2013 12:47 PM
I have been having trouble trying to open any proucts from the design suite packge. I get an error "a valid license could not be obtained by the network license manager."
I am the only one using the design suite product so there should be no problem with license seats at all. I have tried many other forum posts about the subject none of which seemed to help.
Thank you for any help in advance!
TravisNave
Message 2 of 14 (984 Views)
Re: Licensing Error [-4.132.0] PDSU 2013
07-03-2013 01:53 PM in reply to: joeltsack
The -4 error simply means that you are out of licenses.  Do a status enquiry from LMTOOLS and it will tell you where your license is checked out.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
joeltsack
Message 3 of 14 (958 Views)
07-08-2013 04:58 AM in reply to: joeltsack
The problem is now fixed although I did absolutley nothing to fix it. The autodesk programs work perfectly fine now. I am not sure why or what happened. Thank you for your help.
TravisNave
Message 4 of 14 (944 Views)
07-08-2013 09:37 AM in reply to: joeltsack
The license manager resets at midnight.  So if there was a stuck license, perhaps it unstuck itself.  :smileyvery-happy:
joeltsack
Message 5 of 14 (870 Views)
07-31-2013 05:07 AM in reply to: TravisNave
The same license error has happened again. I did a status enquiry from LMTOOLS and this is what I got.
Status
Flexible License Manager status on Wed 7/31/2013 08:05
[Detecting lmgrd processes...]
License server status: @MT-ENG2
    License file(s) on MT-ENG2: C:\Program Files\Autodesk\Inventor 2013\LICPATH.lic;C:\Program Files\Autodesk\AutoCAD 2013\acadm\LICPATH.LIC:
lmgrd is not running: Cannot connect to license server system.
 The license server manager (lmgrd) has not been started yet,
 the wrong port@host or license file is being used, or the
 port or hostname in the license file has been changed.
Server name:   MT-ENG2
License path:  @MT-ENG2;
FLEXnet Licensing error:-15,570
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
License server status: @mtacv
    License file(s) on mtacv: C:\Program Files\Autodesk\Inventor 2013\LICPATH.lic;C:\Program Files\Autodesk\AutoCAD 2013\acadm\LICPATH.LIC:
Server name:   mtacv
License path:  @mtacv;
TravisNave
Message 6 of 14 (849 Views)
07-31-2013 09:10 AM in reply to: joeltsack
Stop and start the service.
Did anything change like with the NIC or the hostname?
joeltsack
Message 7 of 14 (844 Views)
07-31-2013 09:42 AM in reply to: TravisNave
The NIC or hostname did not change.
TravisNave
Message 8 of 14 (836 Views)
07-31-2013 09:51 AM in reply to: joeltsack
Your status enquiry shows two different license managers.
joeltsack
Message 9 of 14 (828 Views)
07-31-2013 10:13 AM in reply to: TravisNave
I dont understand why that is like that.
TravisNave
Message 10 of 14 (815 Views)
07-31-2013 10:34 AM in reply to: joeltsack
Make sure you only have one service listed under Config Services.  And on the first tab, check the box to ignore system environment variables.  Stop and start the service and see if it is working again.
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
