-15 usually means your license server and client have communication problems, if you can confirm the license server runs ok? you can check it by perform status enquiry in the lmtools. If the server ok, then you need to ensure the port 2080 and 27000-27009 is open, try to close firewall on the server and client to see if the problem can be solved.
Emily Xu, Autodesk Product Support
We appreciate your quick feedback on this forum
