Is it possible to license 2 products using the same server and software i.e. maya 2011 and 3d Studio Max licensed on one server using flexlm license manager?
Absolutely. You can license all the products on one server. Just combine the PACKAGE and INCREMENT portions of your license files together into one file. Autodesk activations or your reseller can assist you with this if need be.
Thanks for that, great news.
I have another problem, I've set up Flexlm with my license file but I'm getting a 15.570 error.
I had this problem a couple of weeks ago on another server, it was fixed by creating DEP exceptions for the executables.
I have done this again but I'm still getting the same error. The hostname and MAC address in the file are correct.
Any Ideas?
Typically -15 is caused by an invalid license file. It can also be caused by a firewall or simply that the license manager has not yet been started. On newer machines, it is sometimes a result of IPv6 and IPv4 connectivity. So make sure you can ping the server and get an IPv4 response.
