It seems that other people got this message about a license error when starting maya 2012:
License was not obtained
Tried Maya 2012 (657D1 2012.0.0.F), error 20
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
environment variable MAYA_LICENSE='unlimited'
License file override:
environment variable MAYA_ALT_EN is not set
the solutions in many threads are referred to win os, but I run maya 2012 in a MacBookPro6,2 with Mac OSX 10.6.8
Thanks in advance for any help,
best
Sergio
Hi @jose.garcia
Have you tried all the troubleshooting steps outlined in @jessica.t's post above?
Hey, I am having the same trouble with Maya 2016. Tried all the steps above. When I try to solve the "error 20" thing Terminal says:
Oscars-Mac-Pro:~ Oscar$ adlmreg –u S <657H1> 2015.0.0.F
-bash: 657H1: No such file or directory
Oscars-Mac-Pro:~ Oscar$ adlmreg –u N <657H1> 2016.0.0.F
I have downloaded the latest service pack "Autodesk_Maya_2016_SP3_EN_JP_ZH_Mac_OSX"
I am running OS X 10.10.5 on a 2012 12-core tower mac
(EDIT: I accidentally put "2015" in one of the command lines, but I get the same result with "2016":
Oscars-Mac-Pro:~ Oscar$ adlmreg –u S <657H1> 2016.0.0.F
-bash: 657H1: No such file or directory")
Hello @Anonymous,
Sorry to hear you are experiencing an issue installing your software, because of error 20.
Try conducting these steps:
*If the above does not work you may what to try a clean uninstall and reinstall of the product, you may be encountering an incomplete download.
I hope this helps, please keep us posted.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Checked now, there is no such folder. Just the Maya 2017 folder.
Edit: sorry, my bad. Need to install Maya 2016 again:)
I have tried everything above, and even made similar mistakes as the other guy who had the same issue. But resolved them, and now I am going to try and attempt your solution. I can follow along , however after I get into the autodesk file, from the library, the only folder left is one that says ADUT, which leads me no where. Is there anything else I can do?
I am trying to install 2016 on my Macbook Pro , El Capitan.
Thank you ,
Stephen.
Hello @kernse,
I am not sure what error you received. If you could send that over it would be more helpful.
This article covers Mac Install adSSO error on 2016 or newer program installation.
Thank you.
Natasha
Helpful Links:
I am receiving the error message,
Tried Maya 2016 (657H1 2016.0.0.F), error 20
License method:
Product choice:
environment variable MAYA_LICENSE='657f1'
I have also tried downloading and installing the file that you previously mentioned and that did not work.
@Anonymouswrote:Do the following:
1. Press windows button + r to star Run and type 'services.msc'.
2. Click the 'Standard' tab on the bottom.
3. Find 'FLEXnet Licensing.. blaa' and right click for 'Stop'.
4. Right click again for properties and set 'Startup type' to 'Automatic' and press 'Start' below.
5. Apply and you are done!
From http://simplymaya.com/forum/showthread.php?t=36276
For those hunting for a solution, i'm using Maya 2015 student version and this method worked for me.
Hello Johnny
i ve Problems getting Maya 2012 running on windows again, im happy for any help..
greets Alexander
