• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    AgustastaGW
    License was not obtained Tried Maya 2011 (657C1 2011.0.0.F), error 5
    2297 Views, 11 Replies
    09-12-2011 02:53 AM
    I can't figure out what's wrong, i've been searching for a solution for hours now to no avial...
    See image
    If anyone could offer any solutions, it would be greatly appreciated.
    Please use plain text.
    Product Support
    Re: License was not obtained Tried Maya 2011 (657C1 2011.0.0.F), error 5
    09-12-2011 12:00 PM in reply to: AgustastaGW
    Can you check out the suggestions in this post?
    http://forums.autodesk.com/t5/Installation-Licensing/Problem-with-license-License-is-not-obtained/td...
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    Member
    AgustastaGW
    09-12-2011 01:33 PM in reply to: david.lau
    I tried that, and it didn't do anything. Didn't recreate the files, now I just get error 41. So do I put the files back?
    Product Support
    09-12-2011 01:40 PM in reply to: AgustastaGW
    41 = Product Information Table file is not found.   Can you confirm that you have this file:
    C:\ProgramData\Autodesk\AdLM\ProductInformation.pit
    David Lau
    Member
    AgustastaGW
    09-12-2011 04:10 PM in reply to: david.lau
    Well in the link you asked me to try, it says to back-up the files and remove them. When I then tried to reopen maya, I assumed it would try to recreate them and it didn't. So that file is not there, it is however in the back-up folder.
    Product Support
    09-12-2011 06:24 PM in reply to: AgustastaGW
    Can you move the ONLY the .pit file back in the default location?
    David Lau
    Member
    AgustastaGW
    09-12-2011 06:27 PM in reply to: david.lau
    Well that file is inside the AdLM folder, would you like it so the onlything inside the AdLM folder is the .pit file?
    Product Support
    09-14-2011 06:25 AM in reply to: AgustastaGW
    I have attached an image.
    David Lau
    Member
    AgustastaGW
    09-15-2011 05:49 AM in reply to: david.lau
    I dont have a cascadeinfo.cas file, I attached a picture of what the folder looks like...
    Product Support
    09-15-2011 08:01 AM in reply to: AgustastaGW
    I just sent you a private email.  I would like to log a case for you to try to resolve this issue.
    David Lau
