In my small office we have 3 licenses. 2 each AutoCAD Mechanical and 1 each Inventor.
2 of the users require the use of Inventor (at different times) as they are both learning to use Inventor
User 1 has Inventor suite installed, although primarily using the Mechanical included in the suite.
Users 2 has Mechanical installed (mechanical only license) and Inventor installed (same serial as user 1)
Through the use of the License Transfer Utility, User 1 transfers inventor license to User 2. User 2 then uses Inventor just fine.
User 2 then transfers the mechanical license to the "cloud". User 1 attempts to activate Mechanical using User 2's license = NO GO. User 1 has no stand alone installation of Mechanical to match up with the mechanical only license from User 2 and is unable to use Mechanical.
I understand the why the User 2 license does not activate Inventor on User 1's machine, as it is only a license for Mechanical, but I need to find a way to activate Mechanical only during this "flip-flop". Can I install a second instance of Mechanical on User 1's machine that could be come active upon the transfer of User 2's license? Is this allowed? or is there another mechanism by which I could activate on the mechanical portion of the Inventor suite?
Nate Champagne
Solved by TravisNave. Go to Solution.
You need to uninstall the Mechanical from the Inventor Suite and reinstall Mechanical with your single seat of AutoCAD Mechanical. This will take the Inventor license out of the picture and allow both of your users to use their Mechanical seats at the same time. They'd still need to share the Inventor one, however. But it would not affect their use of Mechanical at least.
TravisNave,
Thanks for the reply. Unfortunately, I don't believe this will accomplish the end goal. User 1 & User 2 primarily use Mechanical concurrently. User 1 uses the seat provided by the inventor license, while User 2 uses a mechanical seat. If I were to uninstall the Mechanical installation included with the Inventor seat from User 1 and reinstall Mechanical from User 2, User 1 would then be unable to run Mechanical under "normal" conditions, as both User 1 and User 2 would require the same Mechanical license to use Mechanical but it would be in use by User 2. This would work great under the "abnormal" condition when User 2 needs to use Inventor, as User 2 could be using Inventor while the User 2 Mechanical license would be available for User 1, but it is effectively flip-flopping the scenario to User 2.
Current Config
User 1
Inventor01 (+Mechanical) - ACTIVE
Inventor - Yes
Mechanical - Yes
User 2
Inventor01 (+Mechanical) - INACTIVE
Mechanical02 - ACTIVE
Inventor - No
Mechanical - Yes
Proposed "Normal" Config
User 1
Inventor01 (-Mechanical) - ACTIVE
Mechincal02 - INACTIVE
Inventor - Yes
Mechanical - NO
User 2
Inventor01 (-Mechanical) - INACTIVE
Inventor - No
Mechanical - Yes
Proposed "Abnormal" Config
User 1
Mechincal02 - ACTIVE
Inventor - No
Mechanical - Yes
User 2
Mechanical02 - INACTIVE
Inventor - Yes
Mechanical - No
Does this all become a non-issue If I were go to a network licensing model? Is this possible? And are there costs associated with the network model versus stand-alone?
Nate
Yes, the network model would fix this issue.
I was under the impression that you had 2 Mechanical licenses. One for each person. If that is the case, you do not need Mechanical installed from the Inventor Suite since it is the same product as just the stand-alone Mechanical.
You could network activate your seats for a one-time charge and be done with this issue altogether. Might be worth it in your case because eventually the LTU will fail on you and you'll have activation issues.
yes travis is right the network license of both products would fix this issue
DarrenP
this explans how it works this is for 2010 it also applys to 2011: http://www.youtube.com/watch?v=3Xg7kbZEqcA
DarrenP
more info: http://inventor-certified.com/graphics/2010/Dynamic_Licensing_explained_1.2.pdf
DarrenP
